Results 1 to 13 of 14
06-10-2011, 05:49 PM #1
- Jun 2003
- Gulf Coast
- 148
McQuay RPS050CSY Not loading help needed
Unit operates off return air temp set at 70. At best I it will run at 75% for a very shot time then back to 50%. One thing I did was moved return air temp sensor out side to make it see 96 RAT no change. I am also needing a manual if any one has one it would help due to mine is missing pages
RAT- 74
SAT- 64
Set point- 70
06-10-2011, 06:00 PM #2
Heres a link that has come in handy before...http://www.mcquay.com/McQuay/Literature/Literature
06-10-2011, 10:14 PM #3
- Jun 2003
- Gulf Coast
- 148
Thanks for the link I found info on unit but nothing that that helps with my problem.
If I remember correctly I need a password to access the setup configuration. I had a problem like this a few years ago and I think it was a setting holding the supply air temp up. I have checked my notes but I cant find them for this unit. I placed a call to Mcquay tech support and left messages all day but no call back.
06-11-2011, 01:41 AM #4
06-11-2011, 06:41 AM #5
- Jun 2003
- Gulf Coast
- 148
No unloader just 4 10 ton scrolls 25%=circuit 1 com 1 50%= Circuit 2 com 1 75% = circuit 1 com 2 100% = circuit 2 com 2
06-11-2011, 10:01 AM #6
is your 4th compressor locked out by mechanical device?
06-11-2011, 10:24 AM #7
- Jun 2003
- Gulf Coast
- 148
No its the controls not calling for full load up. All controls are onboard no BAS
06-11-2011, 02:24 PM #8
If it's Microtech 2, Try 4545 as the password. Sounds like it may be set up for DAC instead of SCC
Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
06-11-2011, 02:30 PM #9
- Jun 2003
- Gulf Coast
- 148
Thanks I have that one the one I am looking for is the one that lets you chanr the factory config of saftys ect.
06-11-2011, 03:01 PM #10
What you need is the McQuay service tool software. The local rep might offer it, but it's probably expensive. I got it from the class in Minneapolis. With the Monitor software for Microtech 1, McQuay did not own the software and I guess there was a falling out or something between the two companies, so now McQuay sells that software for like $7k
06-11-2011, 03:41 PM #11
- Jun 2003
- Gulf Coast
- 148
Thanks but that's not what I wanted to hear. I hope tech support will call me back on Monday and I have overlooked something and software is not needed I HOPE
06-11-2011, 04:05 PM #12
Good luck. Let us all know what you find so that others may learn from your experience.
06-13-2011, 06:50 PM #13
- Jun 2003
- Gulf Coast
- 148
Here's what happened I FAILED to use the scroll sideways option on the control display. Had just scrolled over to discharge air limit I would have seen it was set at 59. Live and learn.
