Results 1 to 13 of 15
    May 2011
    San Antonio, TX
    High Side Low, Low Side Low
    La Rosa Ice Cream Dipping Station struggling to hold temperature.
    I cleaned the condensor coil (filthy) with nubrite and painted with coil paint.
    Recovered refrigerant, pressure tested to 150psi, left overnight. Pressure dropped 1psi,
    but ambient temperature dropped almost 30F too, so I figured that's within the limits.
    Triple evacuated down to 300 microns on the last pull and I metered in 10oz virgin r134a
    per the info plate.
    information plate:
    L-14246
    refrigerant: r134a, 10oz
    150/ Low side psig
    335/ High side psig
    Readings:
    ~0psi on suction line next to compressor
    no refrigerant valve on the high side
    128F compressor discharge which corresponds to 193psig
    ~32F evaporator discharge - frost is forming on the pipe,
    but my infrared thermometer reads 40F (?)
    So, it seems that high side pressure is low and the low side pressure is low.
    I originally thought the capillary tube might be plugged, but I would expect
    higher pressure on the high side. Right?
    I'm thinking the compressor is shot. Does anyone have any thoughts on something else I should check before replacing the compressor?
    Would checking the amperage draw on the compressor tell me anything?
    BTW, I am a noob, but I am EPA & Texas licensed (universal).
    Thanks much!
    Couple of things. You should have installed an access fitting on the high side when you had the chance, even if you simply installed a new CAPT-032 Sporlan drier. They have an access fitting built in. Make sure your captube is pointed downhill out of the drier for a liquid seal. (note, when adding a CAPT-032s you must compensate with 1 extra oz of refrigerant.)
    Next, did you think of compensating for the amount of liquid in your gauge hoses for the 10 oz weight? It could be undercharged by 1 or more ounces which is 10% or more.
    An infrared gun will not give accurate line temps to correspond to temperature.
    With the info you have I don't think the compressor is shot. The info plate showing the pressures are "maximum tested limits" and are not running pressures. If your weight is correct then I would suspect blocked captube and/or spun drier.
    Mar 2011
    The suction being 0 psi tells me your compressor is pumping. If you compensated your charge for your gauge hoses and the new drier, the cap tube or drier might be stopped up. You might try to add a couple more ounces of freon and see if that helps.
    As a "rule of thumb" 1/4" service hoses hold 1 ounce of liquid per 3 feet.
    Vapor hoses hold significantly less.
    I hate seeing r134a as a low temp refrigerant.
    Good luck.
    May 2011
    San Antonio, TX
    Quote Originally Posted by Lusker View Post
    I like the idea of the CAPT-032s. I didn't add one because I couldn't get the flare fitting off, have any tricks for that? Should I hit it with a torch to heat it up and loosen it? If it weren't refrigeration, I would use PB Blaster on it, but I didn't want to contaminate the system.
    I charged vapor. First I pulled a vacuum on the hose, then I filled the hose with refrigerant before hitting tare on the scale. I believe that since the hose was full when I started charging, and it was full when I finished charging, it should net out. It was one 3" long, 1/4 diameter hose.
    What type of thermometer would you recommend? Thermocouple with a pipe clamp attachment?
    If the pressures on the info plate are max working temperatures, how does one determine what the pressures should be?
    Thanks again!
    Quote Originally Posted by clearchris View Post
    Thanks again!
    Here's what I would do but it going to cost you labor already preformed.
    Use tubing cutters to remove the old drier. Hook up your nitrogen bottle and blow about 250 lbs of pressure though the captube while leaving the suction valve open. Sweat in a CAPT-032s. Pull another vacuum. Weigh the charge via vapor and let settle (warm up and equalize). Add 1 oz extra for the CAPT-032s. When it equalizes start the system and watch the suction line. Make sure the drier is pointed down so there is a liquid seal at the exit end of the dryer.
    The only problem I believe you to have is undercharge by an ounce or two if the captube is clear but any time you open a system you should replace the drier, spun type or not.
    Use a multimeter with a temp clamp, thermocouple type is correct. There is no need to use one here though.
    There are no "perfect" pressures to look for here. It all depends on sizing and box temp. Call the factory and ask them but you aren't going to get your correct pressures until the box is just about to temp. Cold plates can take a long time to give you correct operating pressures but you will see a frost line.
    Jun 2006
    Readings:
    No disrespect intended.
    Highly superheated vapor temps on the hot gas / discharge temps do not correspond to the pressure temperature relationship at saturation. Significantly more information would be required to predict the SCT with any level of accuracy, your 193 guess is not to be considered close, nor is the infrared reading, they do not cut it for the industry despite marketing hype.
    The compressor amperage would indeed give you some insight if compared to the RLA to determine if the unit was performing near capacity. Unfortunately it is not the end all answer, it is just not that simple.
    You have not provided enough information to determine a lot and not enough to offer much assistance beyond guessing.
    You cleaned a really dirty condenser, you likely have close to the right charge, but that is also open to question to a degree, you are working on a machine with little tolerance for mistakes and you are going to need to approach it differently if you are going to solve the problem and make an accurate diagnosis.
    Weak compressor, real possibility, but no signs of it from info provided.
    Why's that? Just curious
    "It's just like it doesn't work. I mean it seems to be ok now, but it usually like never works"
    "Never an always and always a maybe"
    Quote Originally Posted by dave1234 View Post
    The low side pressures are too close to atmospheric for my liking. Too much of a chance of drawing in contaminants.
    Clearchris,
    Do you understand HOW a refrigeration system works? Do you know what the term saturation temperature means?
    If not, my friend, we're reaching stage. Call a qualified tech out to help you in completing these repairs.
    May 2011
    San Antonio, TX
    I understood that capillary tube (critical charge) systems were a risk of slugging the compressor if there's too much refrigerant. How much is that generally? There's three coils in the suction line before it returns to the compressor, would those help trap any liquid?
    It may trap a little oil but doubtful it will trap refrigerant in a gas state. You can't worry about the manufactures design. Don't try to re-engineer or over think this simple box.
    Overcharging a critical system will depend on the system. Add your weight, wait for results. Add an oz, wait for results. I would not add more than 2 oz unless you go with a CAPT dryer. The CAPT-032s drier will act like a very small receiver as long as you keep a liquid seal on the captube entrance.
    Jan 2010
    I would guess your low side should be at about 4psig. Which would give you about a -5* cold wall.
    How old is that equipment ? Got a serial # ?
    Jan 2006
    Near Atlanta, GA.
    And it's capacity at that low of an evap temp is not that great.
    Of course, I really don't like 134a for much of anything. I thonk we'll see it go away in a few years.
