Results 1 to 13 of 13
    Jun 2011
    northern California
    Hobart LX30H programming
    I need to adjust the detergent pump duration. I can get into service mode by holding Wash while pressing On, and I can get into deeper programing by connecting pins J5-1 to J5-2 while pressing On. I can play with the arrow (▲) and Select buttons, but the display has me a bit mystified as to how to work the system. A truck roll for a man to push little buttons seems extravagant.
    • Is there a chart showing exactly how you navigate to and set the programmable parameters?
    • And how you can display the various measured parameters?
    • And what the LED combinations mean?
    Thanks!!
    Jul 2009
    Is the detergent pump actually on the dishwasher?
    The reason I ask is that my old hobart and now brand new jackson dishwasher has the soap pumps mounted on the wall and the controller inside of that measures the soap level in the wash tank. Detergent levels are set within the soap dispenser that i have.
    Jun 2011
    northern California
    Internal Pump
    Yes, it's the internal pump.
    Nov 2007
    central Nebraska
    It has been awhile since I had to program an LX, but I thought that it was the second to last parameter on the selection screen; the last one was the rinse cycle. It should have a minimum of 7 (?) up to 20 (?) seconds.
    The other problem that I always had was the tubes on the detergent pump getting worn out. They looked just fine, but once you removed them, they were shot.
    Good luck, remember to use plenty of lube if you do change the tubes.
    Rick
    Over the river and through the woods
    press & hold the key which is hidden behind the model (LX30) and the wash key on the control panel.Slide open the control board drawer. You should be able to toggle through the set points pushing the up arrow button on the board. 1 wash temp 2 booster temp 3 F/C option 4 detergent on cycle (0 thru 30, default 7) 5 rinse aid (0 thru 10, default 2) 6 sani time (0 thru 10, default 2) 6 idle shut down (1 thru 6). DE on the various chemical options shuts that option off.
    Jun 2011
    northern California
    Now we're getting soemwhere
    To recap, here's what I've got:
    Service Mode:
    Hold down the wash button while powering the unit up. You can see the sensor readings. The mode stays here and cycles through the options until you power off.
    Initial configuration mode:
    Short pins J5-1 and J5-2 while powering up unit. The display will show "SET." The options are:
    1. Model 18 or 30
    2. H or C or blank variants
    3. Boost 40 or 70ºF (with 70ºF, the wash cycle time goes to 145 sec, up from 85)
    4. PF or Sd. I don't know what this is.
    Parameter Programming Mode:
    During normal operation with the door switch in shut status, press & hold the unmarked button behind the printed model (LX30) and press the wash button. The display will show "SET." Slide open the control board drawer.
    1. wash temp
    2. booster temp
    3. F/C option
    4. detergent on cycle, seconds (0 thru 30, default 7)
    5. rinse aid (0 thru 10, default 2)
    6. idle shut down, hours (1 thru 6).
    After the last item, the mode returns to normal operation.
    chrldwlf, what is the PF/Sd option??
    Jun 2011
    northern California
    How to apply your changes
    After further testing, here's a revision:
    During normal operation after warmup, press & hold the unmarked button behind the printed model (LX30) and press the wash button. The display will show "SET." Slide open the control board drawer.
    1. wash temp
    2. booster temp
    3. F/C option
    After the last item, the mode returns to normal operation without applying any changes. To apply your changes, return to normal mode by again pressing & holding the unmarked button behind the printed model (LX30) and pressing the wash button.
    Another question for chrldwlf: What is DE? Does it display that? When?
    Quote Originally Posted by bernardc View Post
    1. wash temp
    2. booster temp
    3. F/C option
    DE is for the newer LX/LXi models with the chemical sensing board. SD/PF is a rinse time option, SD is standard rinse time, PF runs rinse water until top rear probe is satisfied.
    Apr 2016
    Lxi programming mode
    Quote Originally Posted by chrldwlf View Post
    I have an Lxi-h do you know if it uses the same key sequence to activate programing mode? Can't seem to get this one to go to program mode.
    Sep 2016
    SET problem on LX30H. Dishwasher
    I got a customer with his Lx30H running a cycle or 2 then next to the temp it will display. "SET" . I tried to hold in blind button behind Lx30 and press wash to run setup and i cant get it to do nothong once that set appears. I must reset power to opperate. I even opened up co trol board drawer and tried toggling setpoints when the SET appears to no avail. Any thoughts?
    Jun 2011
    northern California
    Control PCB
    You'll probably need a new controller.
    Sep 2016
    I was thinking the same thing bernardc. But those control boards are very expensive so I needed a second opinion. Now with that would you recommend replacing the U.I. also?
    Jun 2011
    northern California
    Mouse pee
    Quote Originally Posted by Blade Deso View Post
    It's possible that mice made a nice home in the control compartment and peed on the PCB. If that's the case, you can try washing off the pee with water and small squirt of dish soap, and drying thoroughly. Rinse with Everclear 195 pure ethanol which can be mail-ordered in some states where it is illegal to sell it locally; it evaporates faster than water. And it's non-toxic (as long as you don't use it as a beverage). It might work, might not. Disconnect and refurbish all connectors with Caig Deoxit.
