Results 1 to 2 of 2
    Aug 2005
    Smile
    I want to know about noisy level for air handling unit 4 ton
    Because we are going to put it in the sealing?
    My unit York
    Model number = F2FP048N06
    SW FL
    Thumbs up Noise Level
    Variable Speed Air Handler is what you may wish to pursue to minimize noise.
    However, most factors affecting noise are based on the installation. Size of diffusers, registers, filter area, and amount of air flow.
    Condensing Unit is very quiet at < 76 db.
    http://www.yorkupg.com/homeowners/pd...ler_HDB_AC.pdf
    A few upgraded unit at closer to 72 db.
    You should not be able to hear a condensing unit
    inside except in the room directly adjacent to it.
    Designer Dan
