Results 14 to 19 of 19
    Quote Originally Posted by warm View Post
    benncool - I was with the duce(362nd Signal Co.) out of DaLat 68/69 - who were you with??
    "Hang loose with the DUCE"
    I sure was in the same Co. I was there in 65-66. Worked out of Ton Sahn Nhut (Saigon) on south. I only was to the Headquarters once when I was processed in country.
    Small world. Did you do A/C work in the service?
    Myrtle Beach, SC
    I think a vacuum pump would remove all moisture and volatile liquids from the food. That would not be a good thing. if you used it on meat it would be dry like very well done.
    JMHO
    Remember, Air Conditioning begins with AIR.
    Nov 2003
    Skiatook, OK
    26L20 microwave raido repair - was up north at Tuy Hoa/Lang Bian
    /Pleiku
    Welcome Home, Brother
    Don't annoy the combat veteran!!!!
    All gave some - Some gave ALL
    /Pleiku
    We were the lucky ones.
    Here is a picture of me at age 19, working on a gasoline driven AC unit trailer.
    On the older communication vans we would back up one of these trailers for cooling. Probably they phased them out by the time you got there.
    Nov 2003
    Skiatook, OK
    ours were elec. but still trailer mount
    Aug 2005
    Bangor Maine
    What about making some kind of a bowl to marinate meat in?? Then with a deep vac. get all the flavors drawn in? They have things like that for seal-a-meal but it don’t work all that well, not enough vac.
