Results 1 to 7 of 7
    Jun 2011
    ONTARIO
    HELP: No Collar Outlet for My Wood Insert
    There is only a 6" round hole in the wood insert vs. usualy, there would be a outlet collar which from factory built in the back of the insert.
    In this case, what should I do? I need to connect the liners and adapter to the insert. Do I need to weld one?
    Please help.
    Jun 2011
    ONTARIO
    nobody konws ah?
    Jun 2007
    The Twilight Zone
    Shouldn't this post be moved to the Fireplace Forum????
    Jan 2010
    Athens GA
    It sounds very much like you got a faulty unit.There is no telling what other problems there may be.
    Take it back and get a good one.Examine it before taking it home.
    May 2011
    Western, KY
    Call the manufacturer support line.
    S.E. Pa
    Cool
    No, there are a lot of stoves with a smooth appliance collar. Some have a factory rig to attach the pipe from inside. Others can be attached by making and attaching 'L' brackets btw pipe and stove top.
    The first question is, is this a stove certified to EPA Phase II emissions? The second question is answered by the first but is it listed to UL 1482/ ULC B-365-01 by a recognized testing lab?
    If it is unlisted or uncertified, it should not be installed anyway. If it does meet those requirements then it should be installed by a qualified pro., which in Canada is WETT Certified. In the US, that would be NFI Wood Certified, Certified Chimney Sweep, or a F.I.R.E. Certified Inspector.
    It all starts with the attached rating plate and accompanying manual then a call to the mfr. If no rating plate, dump it. If no serial #, dump it. If uncertified dump it. Unlisted, dump. The listed instructions should have information on attaching the pipe. If not, then contact the mfr.'s technical services with model and serial #.
    HTH
    Jul 2011
    Fireplace Forum
    Hey Gary it sure looks like this post is in the fireplaces forum doesnt it! Thanks for checking b4 you posted!
