Thread: Amp Probe
06-05-2011, 12:50 AM #1
Professional Member*
- May 2007
- Central NJ Area
- 647
Amp Probe
What fluke product is a stand alone amp probe ONLY? I only want it to be for measuring amperage. I don't want it to measure voltage or anything else. I had one in the past where i could choose the amp range either from 200, 600, or 1000 i believe and that was all the tool did.
06-05-2011, 01:02 AM #2
Here is a list of their clamp meters. The only one I didnt see was the i1010 (you need to plug it into your multimeter) and its the one I use
http://www.fluke.com/Fluke/usen/prod...ELW&parent=INDExtended dehydration is the key
06-05-2011, 01:05 AM #3
- May 2007
- Central NJ Area
- 647
Thanks, I was looking at their list but didn't see my previous amp probe which disappeared some how. Maybe someone know what i'm talking about? I have the amp probe i plug into my 87 but some time i need to take voltage readings and amp draw the same time so it doesn't work for me.
06-05-2011, 01:22 AM #4
- Mar 2006
- 950
why not get one of the cheaper amp clamps and just use it for amps ?
06-05-2011, 01:54 AM #5I dont install leaks, i just fix em
Sig line removed by Admin*
Lets see if this gets removed..............
06-05-2011, 07:45 AM #6
I too have had several nice amp meters. I carry quite a few meters in my arsenal bag, Fluke 87-5/E2-KIT, i1010, T5-1000, Amprobe ACD-14 TRMS-FX
and the most used amp monitor is my trusty black clamp on Amprobe thats analog.
You definately work faster with a few meters in your bag, sometimes you need more than one.Extended dehydration is the key
