Results 1 to 9 of 9
    New construction what is installed when roughing in?
    SW FL
    Thumbs up Rough-In
    Rough-In:
    Air handler, duct work, diffuser and register (grille) boxes, t-stat wiring, refrigerant lines, bath exhaust fan housing and duct, kitchen vent duct work, if any.
    Final:
    Condensing Unit, Grilles, Bath exhaust Fan,
    T-stat, Start-up
    [Edited by dan sw fl on 09-08-2005 at 06:12 AM]
    Designer Dan
    Thanks Dan...Just another problem I'm having with a incompentent builder and his subs....
    Air handler ,may or may not be included on "rough",depending on location.
    Dash, it would have to be in the attic area and of course they now closed in all the ceilings and walls!!!!
    Apr 2004
    Bartlett, IL
    Hopefully they left an opening, how else would you maintain the equipment?
    Feb 2002
    Houston Tx
    Ever heard of pull down stairs
    Apr 2002
    Pottsboro TX
    Builder's contract
    rjk63,
    It's really important that you the homeowner be fully involved everyday of construction, if possible, with the construction process. A home is a complex series of systems assembled by many different trades and even more different individuals.
    Ask questions if you don't understand the process. Ask questions if you don't see your material selections being installed. Ask questions if you see what you feel is substandard work being done. The sooner a mistake is found the easier it is to fix or be changed.
    The HVAC system is THE most important system and also the most complex because it uses electricity and plumbing in it's operation. It will impact your future enjoyment of the home everyday you live in it.
    Your contract with the builder should detail the equipment used in your HVAC system.
    Good luck.
    Phil
    Apr 2003
    California
    that is how we rough in also as dan sw fl stated unless the furnace or air handler is not in attic. when the furnace or air handler is in garage or closet we install them at trim so they dont get stolen...
