    New York City
    Calculte the wetbulb using Visual Basic Application
    Hello everyone
    I have an Excel sheet
    Without relying on Mr Carrier's Chart ,nor any web based calculators
    I want to roughly calculate the wet Bulb temperature,
    By using the following factors
    Dry Bulb Temperature and Relative Humidity
    I am looking for a formula that I can enter as VBA code
    I realize it is a tall order
    San Diego, CA
    See this other thread:
    http://hvac-talk.com/vbb/showthread.php?t=180271
    Also, someone posted a function you could do in VB on this thread:
    http://www.eng-tips.com/viewthread.cfm?qid=144858
    Minnesota
    Quote Originally Posted by techservices View Post
    Hello everyone
    Browse these. Using them as needed should allow you to do what you need.
    ' VB Functions for calculation of Psychrometric Properties
    ' of moist air. Methods used from ASHRAE publication
    ' Calculate the Logarithm of a number to the base 10
    Function log10(number)
    log10 = Log(number) / Log(10#)
    End Function
    ' Calculate vapor pressure at saturation given dry bulb temp, wet bulb temp, and elevation
    Function psychro_pvs(temp)
    a1 = -7.90298
    a2 = 5.02808
    a3 = -0.00000013816
    a4 = 11.344
    a5 = 0.0081328
    a6 = -3.49149
    b1 = -9.09718
    b2 = -3.56654
    b3 = 0.876793
    b4 = 0.0060273
    ta = (temp + 459.688) / 1.8
    If ta > 273.16 Then
    z = 373.16 / ta
    p1 = (z - 1) * a1
    p2 = log10(z) * a2
    p3 = ((10 ^ ((1 - (1 / z)) * a4)) - 1) * a3
    p4 = ((10 ^ (a6 * (z - 1))) - 1) * a5
    Else
    z = 273.16 / ta
    p1 = b1 * (z - 1)
    p2 = b2 * log10(z)
    p3 = b3 * (1 - (1 / z))
    p4 = log10(b4)
    End If
    psychro_pvs = 29.921 * (10 ^ (p1 + p2 + p3 + p4))
    End Function
    ' Calculate Vapor Pressure given dry bulb temp, wet bulb temp, and elevation
    Function psychro_pv1(db, wb, atm)
    pvp = psychro_pvs(wb)
    ws = (pvp / (atm - pvp)) * 0.62198
    If wb <= 32# Then
    pv1 = (pvp - 0.0005704) * atm * ((db - wb) / 1.8)
    Else
    hl = 1093.049 + (0.441 * (db - wb))
    ch = 0.24 + (0.441 * ws)
    wh = ws - (ch * (db - wb) / hl)
    psychro_pv1 = atm * (wh / (0.62198 + wh))
    End If
    End Function
    'Calculate dew point temp. given Vapor Pressure
    Function psychro_dp(this_pv)
    y = Log(this_pv)
    If this_pv < 0.18036 Then
    psychro_dp = 71.98 + (24.873 * y) + (0.8927 * y ^ 2)
    Else
    psychro_dp = 79.047 + (30.579 * y) + (1.8893 * y ^ 2)
    End If
    End Function
    ' Calculate Enthalpy given dry bulb temp, wet bulb temp, and elevation
    Function psychro_h(db, wb, atm)
    psychro_h = (db * 0.24) + ((1061 + (0.444 * db)) * (psychro_w(db, wb, atm)))
    End Function
    ' Calculate relative humidity given dry bulb temp, wet bulb temp, and elevation
    Function psychro_rh(db, wb, atm)
    psychro_rh = 100 * psychro_pv1(db, wb, atm) / psychro_pvs(db)
    End Function
    ' Calculate Specific Volume given dry bulb temp, wet bulb temp, and elevation
    Function psychro_v(db, wb, atm)
    psychro_v = (0.754 * (db + 459.7) * (1 + (7000 * psychro_w(db, wb, atm) / 4360))) / atm
    End Function
    ' Calculate Humidity Ratio given dry bulb temp, wet bulb temp, and elevation
    Function psychro_w(db, wb, atm)
    vp = psychro_pv1(db, wb, atm)
    psychro_w = 0.622 * vp / (atm - vp)
    End Function
    ' Calculate Humidity Ratio given dry bulb temp, relative humidity, and elevation
    Function psychro_wrh(db, rh, atm)
    wsat = psychro_pvs(db)
    wtemp = 0.62198 * (wsat / (atm - wsat))
    psychro_wrh = (rh / 100) * wtemp
    End Function
    ' Calculate Atmospheric pressure given elevation
    Function psychro_atm(elev)
    Dim el(21), press(21)
    'Altitude Press.
    el(1) = -1000: press(1) = 31.02
    el(2) = -500: press(2) = 30.47
    el(3) = 0: press(3) = 29.921
    el(4) = 500: press(4) = 29.38
    el(5) = 1000: press(5) = 28.86
    el(6) = 2000: press(6) = 27.82
    el(7) = 3000: press(7) = 26.82
    el(8) = 4000: press(8) = 25.82
    el(9) = 5000: press(9) = 24.9
    el(10) = 6000: press(10) = 23.98
    el(11) = 7000: press(11) = 23.09
    el(12) = 8000: press(12) = 22.22
    el(13) = 9000: press(13) = 21.39
    el(14) = 10000: press(14) = 20.48
    el(15) = 15000: press(15) = 16.89
    el(16) = 20000: press(16) = 13.76
    el(17) = 30000: press(17) = 8.9
    el(18) = 40000: press(18) = 5.56
    el(19) = 50000: press(19) = 3.44
    el(20) = 60000: press(20) = 2.14
    i = 1
    Do While elev > el(i)
    i = i + 1
    Loop
    psychro_atm = press(i)
    End Function
    ' Calculate Wet Bulb temp given dry bulb temp, enthalpy, and elevation
    Function psychro_wb(db, h, atm)
    wbtest = db
    Do
    htest = 0.24 * wbtest + (1061 + 0.444 * wbtest) * psychro_w(wbtest, wbtest, atm)
    wbtest = wbtest - 1
    Loop Until htest < h
    wbtest = wbtest + 2
    Do
    wbtest = wbtest - 0.1
    wbtest = wbtest + 0.1
    psychro_wb = wbtest
    End Function
    ' Calculate Enthalpy given dry bulb temp and humidity ratio
    Function psychro_h_w(db, w)
    psychro_h_w = (db * 0.24) + (1061 + (0.444 * db)) * w
    End Function
    A site where I stash some stuff that might be interesting to some folks.
    http://cid-0554c074ec47c396.office.l...e.aspx/.Public
    Jun 2013
    The Unit which used in this equation
    Quote Originally Posted by osiyo View Post
    End Function
    a1 = -7.90298
    a2 = 5.02808
    a3 = -0.00000013816
    a4 = 11.344
    a5 = 0.0081328
    a6 = -3.49149
    b1 = -9.09718
    b2 = -3.56654
    b3 = 0.876793
    b4 = 0.0060273
    If ta > 273.16 Then
    z = 373.16 / ta
    p1 = (z - 1) * a1
    p2 = log10(z) * a2
    Else
    z = 273.16 / ta
    p1 = b1 * (z - 1)
    p2 = b2 * log10(z)
    p4 = log10(b4)
    End If
    End Function
    If wb <= 32# Then
    Else
    End If
    End Function
    y = Log(this_pv)
    Else
    End If
    End Function
    End Function
    End Function
    End Function
    End Function
    End Function
    'Altitude Press.
    i = 1
    i = i + 1
    Loop
    End Function
    wbtest = db
    Do
    wbtest = wbtest - 1
    wbtest = wbtest + 2
    Do
    psychro_wb = wbtest
    End Function
    End Function
    Hello Osiyo
    Could you explain to me what is your unit used for this equations?
    I appreciate if you answer my question
    Minnesota
    The functions expect inputs, and produce outputs in ...
    Degrees Fahrenheit
    Feet
    Inches of Mercury
    Percent
    Pound of Water/Pound of Air (humidity ratio)
    BTU/Pound (enthalpy)
    Cubic Ft/Pound (specific volume)
