Calculte the wetbulb using Visual Basic Application
Hello everyone
I have an Excel sheet
Without relying on Mr Carrier's Chart ,nor any web based calculators
I want to roughly calculate the wet Bulb temperature,
By using the following factors
Dry Bulb Temperature and Relative Humidity
I am looking for a formula that I can enter as VBA code
I realize it is a tall order
 Originally Posted by techservices
Hello everyone
Browse these. Using them as needed should allow you to do what you need.
' VB Functions for calculation of Psychrometric Properties
' of moist air. Methods used from ASHRAE publication
' Calculate the Logarithm of a number to the base 10
Function log10(number)
log10 = Log(number) / Log(10#)
End Function
' Calculate vapor pressure at saturation given dry bulb temp, wet bulb temp, and elevation
Function psychro_pvs(temp)
a1 = -7.90298
a2 = 5.02808
a3 = -0.00000013816
a4 = 11.344
a5 = 0.0081328
a6 = -3.49149
b1 = -9.09718
b2 = -3.56654
b3 = 0.876793
b4 = 0.0060273
ta = (temp + 459.688) / 1.8
If ta > 273.16 Then
z = 373.16 / ta
p1 = (z - 1) * a1
p2 = log10(z) * a2
p3 = ((10 ^ ((1 - (1 / z)) * a4)) - 1) * a3
p4 = ((10 ^ (a6 * (z - 1))) - 1) * a5
Else
z = 273.16 / ta
p1 = b1 * (z - 1)
p2 = b2 * log10(z)
p3 = b3 * (1 - (1 / z))
p4 = log10(b4)
End If
psychro_pvs = 29.921 * (10 ^ (p1 + p2 + p3 + p4))
End Function
' Calculate Vapor Pressure given dry bulb temp, wet bulb temp, and elevation
Function psychro_pv1(db, wb, atm)
pvp = psychro_pvs(wb)
ws = (pvp / (atm - pvp)) * 0.62198
If wb <= 32# Then
pv1 = (pvp - 0.0005704) * atm * ((db - wb) / 1.8)
Else
hl = 1093.049 + (0.441 * (db - wb))
ch = 0.24 + (0.441 * ws)
wh = ws - (ch * (db - wb) / hl)
psychro_pv1 = atm * (wh / (0.62198 + wh))
End If
End Function
'Calculate dew point temp. given Vapor Pressure
Function psychro_dp(this_pv)
y = Log(this_pv)
If this_pv < 0.18036 Then
psychro_dp = 71.98 + (24.873 * y) + (0.8927 * y ^ 2)
Else
psychro_dp = 79.047 + (30.579 * y) + (1.8893 * y ^ 2)
End If
End Function
' Calculate Enthalpy given dry bulb temp, wet bulb temp, and elevation
Function psychro_h(db, wb, atm)
psychro_h = (db * 0.24) + ((1061 + (0.444 * db)) * (psychro_w(db, wb, atm)))
End Function
' Calculate relative humidity given dry bulb temp, wet bulb temp, and elevation
Function psychro_rh(db, wb, atm)
psychro_rh = 100 * psychro_pv1(db, wb, atm) / psychro_pvs(db)
End Function
' Calculate Specific Volume given dry bulb temp, wet bulb temp, and elevation
Function psychro_v(db, wb, atm)
psychro_v = (0.754 * (db + 459.7) * (1 + (7000 * psychro_w(db, wb, atm) / 4360))) / atm
End Function
' Calculate Humidity Ratio given dry bulb temp, wet bulb temp, and elevation
Function psychro_w(db, wb, atm)
vp = psychro_pv1(db, wb, atm)
psychro_w = 0.622 * vp / (atm - vp)
End Function
' Calculate Humidity Ratio given dry bulb temp, relative humidity, and elevation
Function psychro_wrh(db, rh, atm)
wsat = psychro_pvs(db)
wtemp = 0.62198 * (wsat / (atm - wsat))
psychro_wrh = (rh / 100) * wtemp
End Function
' Calculate Atmospheric pressure given elevation
Function psychro_atm(elev)
Dim el(21), press(21)
'Altitude Press.
el(1) = -1000: press(1) = 31.02
el(2) = -500: press(2) = 30.47
el(3) = 0: press(3) = 29.921
el(4) = 500: press(4) = 29.38
el(5) = 1000: press(5) = 28.86
el(6) = 2000: press(6) = 27.82
el(7) = 3000: press(7) = 26.82
el(8) = 4000: press(8) = 25.82
el(9) = 5000: press(9) = 24.9
el(10) = 6000: press(10) = 23.98
el(11) = 7000: press(11) = 23.09
el(12) = 8000: press(12) = 22.22
el(13) = 9000: press(13) = 21.39
el(14) = 10000: press(14) = 20.48
el(15) = 15000: press(15) = 16.89
el(16) = 20000: press(16) = 13.76
el(17) = 30000: press(17) = 8.9
el(18) = 40000: press(18) = 5.56
el(19) = 50000: press(19) = 3.44
el(20) = 60000: press(20) = 2.14
i = 1
Do While elev > el(i)
i = i + 1
Loop
psychro_atm = press(i)
End Function
' Calculate Wet Bulb temp given dry bulb temp, enthalpy, and elevation
Function psychro_wb(db, h, atm)
wbtest = db
Do
htest = 0.24 * wbtest + (1061 + 0.444 * wbtest) * psychro_w(wbtest, wbtest, atm)
wbtest = wbtest - 1
Loop Until htest < h
wbtest = wbtest + 2
Do
wbtest = wbtest - 0.1
wbtest = wbtest + 0.1
psychro_wb = wbtest
End Function
' Calculate Enthalpy given dry bulb temp and humidity ratio
Function psychro_h_w(db, w)
psychro_h_w = (db * 0.24) + (1061 + (0.444 * db)) * w
End Function
The Unit which used in this equation
End Function
a1 = -7.90298
a2 = 5.02808
a3 = -0.00000013816
a4 = 11.344
a5 = 0.0081328
a6 = -3.49149
b1 = -9.09718
b2 = -3.56654
b3 = 0.876793
b4 = 0.0060273
If ta > 273.16 Then
z = 373.16 / ta
p1 = (z - 1) * a1
p2 = log10(z) * a2
Else
z = 273.16 / ta
p1 = b1 * (z - 1)
p2 = b2 * log10(z)
p4 = log10(b4)
End If
End Function
If wb <= 32# Then
Else
End If
End Function
y = Log(this_pv)
Else
End If
End Function
End Function
End Function
End Function
End Function
End Function
'Altitude Press.
i = 1
i = i + 1
Loop
End Function
wbtest = db
Do
wbtest = wbtest - 1
wbtest = wbtest + 2
Do
psychro_wb = wbtest
End Function
End Function
Hello Osiyo
Could you explain to me what is your unit used for this equations?
I appreciate if you answer my question
The functions expect inputs, and produce outputs in ...
Degrees Fahrenheit
Feet
Inches of Mercury
Percent
Pound of Water/Pound of Air (humidity ratio)
BTU/Pound (enthalpy)
Cubic Ft/Pound (specific volume)
- You may not post replies
- You may not edit your posts
Forum Rules
