Results 1 to 7 of 7
    May 2011
    Need advice on line set and oil strap
    Hi please give me some advice and recommend ,used 3T with 7/8 SL 3/8 LL but my split SYS between condenser and coil about 15feet and 1 FT different heigh ,do I need install oil strap and can I use 7/8SL instead 3/4 SL is there any different of efficiency ,performance affect or not any suggest very appreciate .
    Jun 2011
    long island, NY
    You don't need oil trap and for residential systems you can go as high as 1 1/8 in SL its a little more efficiant. If your lines are 100 ft or more you will need a LL solinoid.
    May 2011
    HI ac andy thank for the advice but let say with 15fts can I use 7/8 " or can i uesd 3/4 " for SL which one most affective
    Jun 2011
    long island, NY
    7/8 is better. You can go larger in SL on unit specs but never go smaller. It is more efficiant but not by a lot.
    May 2011
    So let go little bit detail 3T unit , the the length SL from Condenser to Evaporator coil is 15 FTS if I do have install 7/8" line SL which is better compare with 3/4" SL or I must go with 3/4 " what would be see any different and if I go with 7/8" would see any different or any affect >?.Thank a lot
    Jun 2011
    long island, NY
    It is better to install 7/8 in case you go with a high efficiancy unit with 410a some units 16 seer and above require 7/8 - 1 1/8
    Mar 2006
    Denver/Boulder
    Hmmm...
    has no one read the site rules?
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
    For Consumers:
    For HVACR Professionals:
