Results 14 to 26 of 64
    Sep 2006
    Chicago
    Quote Originally Posted by marter View Post
    110*/270psi
    You have to remember though with a warm box and high suction pressure you're going to be running higher than normal head and your condenser may not be in the perfect shape as it was new.
    How old is this equipment?
    Mar 2006
    Quote Originally Posted by dangpgt97 View Post
    fairly new, id say no more then 5years.. make by RDI
    Sep 2006
    Chicago
    It this the first really hot day over there?
    Dec 2009
    northeast pa
    Sounds like u are getting alot of humidity in the box.300 psi is nothing on a that hot of a day.
    Mar 2006
    not the first hot day, been in the mid 90 for a week or two
    Jan 2010
    Is that low end Carrier equipment ? Probably has no head pressure control for low ambient conditions. Just fan cycling.
    Mar 2006
    "a manitowic company" sticker was on it.
    no high pressure controls
    Dec 2009
    northeast pa
    Were they stocking the freezer.Are the evap fans running the way.
    Jan 2010
    So what happens in the winter ? Is it mild there then ?
    Pearland Texas
    In my opinion the suction pressure is too high. I work in the Houston area. I have seen freezers that would not pull down on a hot day when the condensers were on the roof. Even though the suction pressure would be close to normal the freezer wouldn't pull down. I think the condensers were minimal capacity and couldn't reject enough heat when they were on the roof.
    Mar 2006
    sometimes can be mild. i dont know how this unit will cope when its cold, but for now im not concerned with that.
    Jan 2010
    What model number do you have ? RDI does make a 120 series for high ambient conditions. They come with a larger condenser.
    Dec 2009
    northeast pa
    suction pressure is to high to be a txv.suction pressure would have to be below 10psi to feed enough liquid to raise discharge pressure.
