Results 1 to 9 of 9
Thread: Pressure relief valve question
09-05-2005, 03:11 AM #1
Member
- Dec 2004
- Puyallup,WA.
- 51
Where should a pressure relief valve be placed on the "high side" of a refrigeration system, liquid or vapor?
09-05-2005, 11:31 AM #2
- Nov 2004
- 2,923
Hey coldmilk,
I dunno but will take wild guess.. and let some X refer guy correct me,if need be.
I will say discharge.(vapor)
09-05-2005, 11:42 AM #3
This answer to this question is most likely found somewhere within the ASME Pressure Vessel Code, the ASHRAE Safety Code and the like.
In my experience the codes address the venting of pressure vessels, so I'd vote for the relief valve's location to be on the receiver....at or near the top where vapor is most likely present. If there are large lowside vessels like chillers, accumulators, low-pressure receivers, etc.....they will require reliefs as well. Again, I've only seen the reliefs located at or near the top, where there's vapor.
So it's possible that you need relief valves in more than one point in the system and both on the high and low sides.
09-05-2005, 12:14 PM #4
- Dec 2003
- Location!, Location!
- 929
I'll also vote for on the discharge line - vapor- and not able to be valved off, excepting the discharge service valve on the compressor. I have seen passed installs where the prv was on the water-cooled condenser shell taps. Also be aware of the need to remote vent line if in a confined space.
09-05-2005, 04:06 PM #5
- Aug 2002
- 6,047
once again...Ice is right.
09-05-2005, 04:16 PM #6Basically, there has to be one for every pressure vessel.Originally posted by icemeister
Doesn't matter what type of fluid is in it, or what state of matter it has taken on. Just has to be one on every pressure vessel...
09-05-2005, 05:00 PM #7
- Sep 2005
- 3
ABSOLUTLY VAPOR
09-05-2005, 11:44 PM #8Explain the use of the EXACT SAME CODE for hot water boilers, then.....Originally posted by refrigerant_12
ABSOLUTLY VAPOR
09-08-2005, 06:08 PM #9
Member
- Dec 2004
- Puyallup,WA.
- 51
Thanks for the info fellas.
