Thread: overflow device
    Jun 2000
    Florida
    I want to install an overflow device on my vertical A/H located on the second floor. I can not use a drain pan since that will interfer with the Return air opening .What are your suggestions?.No pump to be installed.(gravity flow)
    Jerry
    A contractor can install a float switch.
    Apr 2004
    That or a secondary drain routed to a place where it would indicate to you there is a problem with the primary drain such as over the kitchen window or even a bath tub.
    Jun 2000
    Florida
    Thank you.
    Jerry
