Thread: Payne Heat pump
    Feb 2011
    Atlantic City, New Jersey
    Confused Payne Heat pump
    I am an HVAC division Manager and have never seen this before.
    I have a Payne Heat Pump Condenser that runs fine all winter, however when the summer hits the condensing unit will only run for fifteen minutes or so? Any thoughts on what is causing this?
    I don't know
    Does the unit defrost properly in the winter?
    You can figure out what's happening by determining which safety is shutting down the unit.
    Feb 2011
    the unit ran fine with great defrost all winter long. only on hot days does this happen.
    Feb 2011
    Quote Originally Posted by whoward View Post
    no issues during winter months.
    Aug 2010
    Should be relatively easy to figure out. Get your gauges and meter and do a diagnostic on the unit.
    Feb 2011
    Actually spoke with Payne factory yesterday and when these are installed with additional line set lengths the scale for adding more refrigerant is wrong and causes us to overcharge the system by one pound. We recovered the one pound of gas and now the system is working perfectly again.
