Results 1 to 8 of 8
    Dec 2010
    texas
    need all pros opinions
    ok so the question is simple. what brand in your opinion is the quietest A/H unit on the market to match up with a 13 seer heat pump unit? im thinking of going with a goodman GSZ13036 for the heat pump and a goodman AEPF303616 for the A/H unit. this customer is on a serious budget so need to keep price as low as possible but she is wanting to relocate inside unit but she cant afford it.the only problem she has with old unit is the location she says the unit makes to much noise. i told her that A/H are alot quieter than they use to be. so just wanted to hear what everyone thought. thanks
    Fairfield county Connecticuit
    Variable speed AHU
    Might want to use an air handler with an X13 motor, the rocking the VS does before starting up may ne louder then what she will like.
    Dec 2010
    Quote Originally Posted by martin&sonsa/c View Post
    The ductwork (supply and return) has the biggest impact on the noise. Get that right and she should be happy.
    Incorporate a hi-eff. pleated 4-5" filter also to be safe.
    What George said!
    But actually, with an undersized duct system, the VS motor air handlers can be NOISY just cuz they have the extra strength to try to move more air than the duct system should have.
    Dec 2010
    What George said!
    Exactly right (B. L.). The EMC motor will ramp up with a poor duct design and become noisy.
    I worked for a company (probably like most) that could care less about the ductwork. I was called to talk with the homeowner about a temp. differance in the home. When I walked in the door, I could hear the EMC blower about ready to come unclued. I knew it was short on return and it (really) was. I didn't dare say it was installed wrong. I would have gotten in a lot of trouble.
    The boss always hated it when I added returns.
    Jan 2010
    Athens GA
    Sounds like you want the tall short one with the small large coil with the cheapest large price.or do you want the most expensive cheap price?
    Dec 2010
    texas
    LMFAO!!! Rep. thats exactly what im looking for lol. but really the duct work is fine . im actually down sizing the old system is a 5 ton and im installing a 3 ton then rerouting ductwork and adding some to the other side of the house where im going to install a 2 ton system for second zone. so lets hear what yall think of that.lol.cant wait to hear this lol.
