Results 1 to 13 of 14
    Aug 2005
    Thumbs up
    which airconditioner performs best carrier or any other?
    Tyler, TX
    They all perform the same.
    You might want to ask...
    Which one is the best value?
    Which one will last the longest?
    Which one is the quietest?
    Which one is the easiest to work on?
    Which one is easiest to get parts for?
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    SW Wisconsin
    It is the installer(s) that make the difference in equipment performance!
    First, a thorough heat-gain calc analysis of your home should be performed looking at all the possibilities to reduce it, before sizing the equipment and ductwork to handle the load.
    Second, is sizing the system to fit the heat-gain load. The condenser should never be oversized.
    The HVAC knowledge and skill of the company personnel and their integrity to do the best possible job to achieve the optimal efficiency that your A/C system is engineer-designed to deliver.
    http://www.udarrell.com/air-conditio...tent-heat.html
    The equipment that is the best value for your particular condition will once again depend on the experienced knowledge and selection skills of the selected contractor to explain and illustrate in graphic terms why that particular equipment application will return the best performance and savings in your climatic and home conditions.
    There are scores of equipment combination choices from which to select the one(s) best suited for your conditions. Those best choices are not always the higher-(est) SEER applications. - Darrell
    Besides the best install and properly sized, I prefer to see a scroll compressor outdoor unit, preferably with louvered cabinet, and a TXV on the indoor coil.
    Florida
    Goodman 13+ seer with a txv.......great bang for the buck. I'd look into Rheem/Ruud also. You can keep your Carrier/Tranes, as they are nice pricey high end units, which cost alot more for service, but do have more comfort options, if that's what you're after(quieter, higher end controls)
    Jul 2005
    What is the advantage of a louvered cabinet?
    Jul 2005
    That narrows the field.
    Jul 2003
    Massachusetts
    seriuosly, get a few product brochures and check out the cutaway diagrams. There really is very little difference. In my opinion, Carrier is very overrated. Heil is worth checking out.
    "ok, everyone just calm down."
    burlington county n.j.
    any other
    PA/DE area
    I think it the guy who put's it in because he the one that has to to stand behind and repair. We offer TEN YEARS PARTS and Labor on higher SEER stuff,it just seems to last longer.That might be in PA.
    It's NOT the BRAND,it's the company that installs it!!!!!
    Feb 2005
    [/B]
    I heard the wire cabinets are more expensive to make, and maybe Carrier will be doing louvered next year.
    SW FL
    the 1 u hav that werks
    Designer Dan
    Huntsville,AL
    1 which makes the house comfortable (to you ) & is paid 4 !
