Results 1 to 10 of 10
    May 2011
    clayton nc
    leak detectors, are they reliable?
    I was wondering if detectors are a part of everyones tool bag, or if they are a waste of money. I inherited a CPS LS780B at work and was wondering if I can trust it as quickcheck on a running system?
    May 2011
    New York
    I would suggest you try it when you find a leak. Gauge it by seeing how far away from the leak it triggers the alarm. This will be the only way to tell if it works or not. Some detectors are prone to tip failure, check if yours has replaceable tips and if so, does yours need a new one ?
    I only use a leak detector when I need a general area, then pinpoint the spot with Fantastik. Most times I dont even bring the detector along for the ride, the other evidences of leaks are hard to miss.
    Extended dehydration is the key
    May 2011
    clayton nc
    got ya, thanks
    Denver, CO
    Get you one of those test vials that simulate a .10 oz. A year leaK.
    Gotta link Tiger?
    Wish we could still use a halide torch
    Denver, CO
    May 2011
    clayton nc
    The link isnt working.
    Indiana
    i think this is what he was pointing to
    Prest-O-Lite® Halide Leak Detector
    Denver, CO
    Here I found it for $7 cheaper on eBay.
    http://cgi.ebay.com/ws/eBayISAPI.dll...3249&hlp=false
    May 2011
    clayton nc
    cool thanks
