Thread: Rheem/Bryant
    Aug 2005
    What are your thoughts on Rheem/Bryant condensing units. I prefer the Rheem if there is room for it. Will the Bryant compressor hold up as long as the Rheem Copeland scroll?
    Both without leaks, charged correctly, sized properly, etc. Thanks in advance.
    Apr 2004
    I would depend on which models you are considering, both make a high end, and an entry level machine. No matter which you choose, you need to match the indoor coil. If you are just changing the outdoor section, you either better think twice or consider the make and model of the coil that you plan on using.
    SW Wisconsin
    Get the scroll compressor and a (TXV) Thermostatic Expansion Valve refrigerant control on the matched evaporator.
    Go for all copper coils, NO AL.
    Do NOT oversize the matched system!
    http://www.udarrell.com/air-conditio...tent-heat.html
    AOP Forum Rules:
    Rules for Posting
    Rules For Equipment Owners
    Equipment Owners Find a Contractor HERE!
    Free online whole house load calculator & Sizing: http://www.loadcalc.net/ Anyone can use it...!
    udarrell
    Aug 2005
    Thumbs up
    UDARREL, Thanks for all the info!
