Results 1 to 9 of 9
    May 2011
    clayton nc
    poor air flow in one register
    I work at an apt community and one of the registers has almost no air flow. Does any one have any tips on how to find the restriction without tearing apart the whole ceiling? Its an all flex system with the exception of the plenum.
    I know a camera would work to some extent but I cant even get this company to buy the proper tools for measuring superheat.
    Thanks in advance for your patience with my stupid question.
    Paul
    Northeast Ohio
    Has it always been an issue or is this a recent problem?
    DEM
    May 2011
    clayton nc
    Unknown, the tenant just moved into the apt, and my company just bought the place. I dont see any fresh drywall work or anything so Im unsure what the cause could be. Also, its the 2nd floor of a 3 story building and theres no evidence of recent work on the 3rd floor.
    Jun 2006
    did you try looking inside register to see prior tenant blocked it with something
    Dec 2010
    Mooresville
    maybe the system was never balanced
    Orange County NY
    Quote Originally Posted by pfischer View Post
    Paul
    In my experience apartments, & condo's are usually flexed, and there are always low flow registers because of improper design and installation. Don't worry about the one register, unless you intend on replacing all the duct!
    May 2011
    clayton nc
    Quote Originally Posted by frio View Post
    Yes, I wish it was that easy.
    May 2011
    clayton nc
    Quote Originally Posted by avilleg0 View Post
    I dont think theres much I can do about that, the A/H has a fiberboard (correct term?) plenum and three straight take offs . the bedroom being the longest and its only about 10-15 feet away. Theres literally no room to work on the unit as they are built into a closet with about 6 inches of clearance all around.
    I do have to service the blower and clean the coil but I was just hoping maybe someone had a trick that I havent thought of.
    May 2011
    clayton nc
    Quote Originally Posted by jackpiner View Post
    Yeah I figured that was the case,but the tennant is complaining about the room in question being too warm. I was just hoping I wouldnt have to tear the drywall down.
