Results 1 to 13 of 14
    Jul 2010
    Edmonton
    Remedy for shaft coatings?
    That tar like coating that factories put on motor shafts and squirrel cage shafts, I'm assuming for corrosion resistance.
    How do you get it off? I'm thinking the next time I run into that stuff I'm just going to burn down the building
    What does everybody do to get this junk off?
    I came upon this pile of junk, the torch has been passed. I take ownership of things shaped before me, it is now my responsibility.
    But what are you suppose to do when you see yourself in that pile of junk?
    Mar 2009
    central illinois
    sandpaper
    work to live not live to work.
    Jun 2008
    Windsor, Ont.
    Wire wheel on an angle grinder.
    Boise, ID
    WD-40 and good sandcloth.
    If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
    Oct 2005
    Phoenix, Arizona
    Wire wheel Sometimes I heat it up with a hand torch and then spray it with water immediately. Makes it easy to sand off
    RTFM!!!
    Arizona
    Quote Originally Posted by Gib's Son View Post
    Yup, comes rite off with WD-40.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    May 2009
    In the Hudson Valley of New York
    I keep Never Seize in my tool bag, when ever we replace a motor or a blade we coat the shaft with never seize and next time we replace a motor, it is a breeze to get the blade back off. And yeah, WD 40 dissolves tar easily.
    May 2011
    Las Vegas, Nevada
    Spray it with brake cleaner and it should wipe off with ease. Also coat it with a little anti-seize before you install the sheave. If not for you, for the next guy.
    Hope this helps.
    Jan 2010
    Oklahoma City
    I use my knife to scrap off what I can then sand paper
    Ontario Canada
    Works great!
    Vancouver , Canada
    Tar Trouble
    Yes, WD-40 works pretty well; laquer thinner works better, however, it is more toxic.
    I too use never seize on the shafts - makes doing it the next time a nicer experience.
    Freonguy
    Superheat and subcooling tell it all !
    Southeastern Pa
    Go to the auto parts store and get a can of CRC Brake Kleen for this purpose and Lectra Motive spray for contacts.
    Nov 2005
    Rust buster in the little bottle works well.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
