Results 1 to 13 of 14
    May 2011
    Carrier vs. Trane?
    I've been lurking here for about a month now trying to learn all I can BEFORE I had the contractors out to estimate a new system for the house. Thanks so much for sharing your wealth of knowledge.
    Info:
    Live in the DFW metroplex in Texas - HOT and humid. House is 1710sf one story. Lots of shade from big oak trees.
    Electric A/C and natural gas heat.
    I've had 6 different contractors come to the house to estimates. The four that did load calculations all came back with the same size unit for the house - 3.5 ton single-stage unit or 4 ton two-stage unit.
    Price of the systems I'm asking about are in the ballpark of each other. I'm looking for information on the quality and reliability of the systems. Any information will be GREATLY appreciated.
    Systems:
    Trane XL 16i/gas - 17 SEER - ARI# 3935414 (model #s from ARI website)
    Outdoor unit - 4TTX6048E1
    Indoor unit - 4TXFH063CZ3
    Furnace - UD2C080B9V4
    Carrier Comfort Series - 16.5 SEER - ARI# 3636829 (model #s from ARI website)
    Outdoor unit - 24ACB748A
    Indoor unit - CNPH*6024A
    Furnace - 58PH*110-20
    Carrier Performance Series - 17 SEER - ARI# 3638152
    Outdoor unit - 24APA748
    Indoor unit - CNPHP61
    Furnace - 5BCVA110
    Performance series will end up being abt $ more than Comfort Series. Comfort Series and Trane system are almost identical in price. (Hope I haven't overstepped my bounds mentioning the differences.)
    Jun 2009
    Albuquerque NM
    489 or 428 sq.ft. per ton?
    What kind of load calculations did they do?
    Massachusetts
    First, big trees of any type don't count when it comes to the load calculation. Trees are temporary for calculation purposes. The come down in storms, via chainsaw or for other reasons.
    You've gotten quotes from several well respected companies that have all gone to the trouble of doing a full room-by-room load calculation and you've seen that they are all telling the 'same story' when it comes to size. The rest is now up to you regarding which company you trust the most. Any equipment comparison has a lot more to do with the installing company than with the manufacturer. Just call the manufacturers and ask them. They try very hard to keep the best contractors and get rid of the fly-by-nights that ruin their reputations. Once the system is installed, if there's problems, it's their name badge on the equipment and they get the black eye.
    You'll likely get lots of well meaning opinions here as to one being better than the other but Carrier, Bryant, Trane, York and Rheem/RUUD are all top drawer companies whose products are on par with each other. They've each taken turns at manufacturing issues so there's never a guarantee with any but that's why a proper installation and a good installing company are so important. Trust you 'gut' and go with the company with which you are most comfortable.
    Jun 2009
    Albuquerque NM
    I could easily find 6 contractors who would do a "load calculation" and all give me oversized AC. Just sayin ...
    Dec 2010
    Quote Originally Posted by ^shane^ View Post
    Info:
    Systems:
    Furnace - 5BCVA110
    Why would the Carrier guy be quoting a 110,000 btu furnace while the Trane is a 80,000 btu.
    So much for the load calc.
    Think BIG!
    BIGGER is better.
    1700 sq ft and 4 ton even for Dallas in a shaded house sure seems like a lot. If you really need that much, probably better off tightening the house or blowing a bunch of insulation in the attic so you can get a smaller unit and save on your electric bills.
    I disagree on trees not counting. All of the trees aren't coming down unless a tornado takes them along with the house. You ignore the nice shade and oversize and you'll be buying one of Teddy Bear's dehums cuz your big A/C doesn't run enough to dehumidify. And forget the 2 stage, I've seen the latent capacity of some of them on low, especially the Trane. Won't help much.
    Same with the furnace. The average 1700 sq ft ranch here would have the 80% 80,000 BTU furnace to heat it when it is -10 outside. So needing that much or more for a mild Dallas is a bit carried away.
    May 2011
    I should have included...
    All four that did the load calculations said I need a 3.5 ton unit. They priced me 4 ton units to get to a 2 stage system (no 3.5 ton 2 stage systems out there). Seems to me that the 2 stage system is a better system (from what I can read and interpret) for dehumidifying the air and for overall efficiency. I understand that a 4 ton unit is too big for the house as a single stage system, but I am under the impression that a 4 ton 2-stage system will run on "low" a vast majority of the time - dehumidifying and cooling - only going to "high" when a bump in cooling is needed.
    Is the 2 stage system overrated?
    Dec 2010
    Is the 2 stage system over rated?
    I agree with B. L. I don't have a problem with 2 speed A/C (or H/Ps) IF your house needs a 4 ton. But oversizing just to "step up" to a 2-speed can spell disaster.
    I know first hand. I was going along just great with my 2.5 ton A/C. When lightning hit it, I put in a 3 ton "2-speed" thinking it would work (de-humidify) better.
    I was soooooooooo wrong. But I learned a very valuable lesson.
    Apr 2008
    TEXAS
    3.5 ton trane xl15i with variable speed 80k furnace and you will be comfortable in big d. the carrier single stage comfort series are good systems as well.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Nov 2010
    Central Florida
    I'm a homeowner (not a pro) but I recently went through the same type of process in choosing a system.
    1) I chose Carrier Comfort series and am very happy with the equipment.
    2) I decided against Trane as I was repeatedly warned their parts are largely proprietary, or said another way Trane isn't as compatible with after-market parts. This can mean longer order times and higher costs. Maybe the pro's on the fourm have more comments to share, but I heard it pretty much from everyone, including Trane dealers as well.
    3) The installation is by far the most important aspect. If you choose the wrong installer it won't matter what system you buy, the end result will be a hoard of headaches & problems. I learned this the hard way.
    4) Refer to #3 again.
    Sonic
    I reduced from a 4 ton to a 3 ton on a large rancher(around 3100 sq ft) some years ago. Solely because of the shade of all the trees that had grown high enough over the last 25 years that it shaded the home's larger windows and skylights.
    Yep, tree shade does count.
    SW FL
    Question
    Info:
    Is that a "Glass House" ?
    Is it more than 50 years old?
    Speculate that a load calc might show < 36,000 BTU/ HR at ~ 93'F.
    Did they all run their calcs at *** 105'F *** ?
    Do you have parties for 20 people or more in the summer?
    ----- The real issue is .. WHY a 3.5 Ton? -----
    Why not a heat pump?
    Designer Dan
    Virginia
    the trane 16i does not dehumidify very well in low stage because the 2 stage compressor reduces to 70 percent capacity but the air flow reduces to 80 percent and on a 5 ton coil to get the seer rating therefore you need to be careful about oversizing .
