Results 14 to 19 of 19
05-30-2011, 07:45 PM #14
06-02-2011, 08:28 PM #15
- May 2011
- 15
06-13-2011, 05:26 PM #16
build date of 1993
43,000 hours
2ed set of Engines
06-24-2011, 10:55 PM #17
- May 2011
- 15
06-24-2011, 10:58 PM #18
- May 2011
- 15
11-05-2011, 12:27 AM #19
- Aug 2007
- northern new jersey
- 18
My experience with the Tecogens has been beyond horrible ! Sorry to rain on anyones sugar coating, but those machines can be a tech's worst nightmare. Brand new startup with the factory rep in the mid 90's , the starters all burnt up...they couldn't turn the engines and compressors coupled together. Then the exhaust from one engine running caused highly acidic water to fill up in the engines of the chillers not used at the time. Then the exhaust heat exchangers ruptured and filled the engines with water again, then the engine and compressor oil heat exchangers (located in a horrible position underneath the hips of the machines) decided to clog with mud from the cooling tower water, Then the vibration of the machines caused the emission control computers (rigidly mounted on the vibrating metal deck of the chiller) to fail one by one until we modified thier mounts with rubber feet, then the fuel mixture valves in the carbs failed, then an engine dropped an intake valve which smashed a hole in the piston, then another chiller broke an oil line and caused a huge fire in the mechanical room, knocking out the main breakers and the power feeds for the elevators...yeah, those Tecos are awesome !
