Results 1 to 2 of 2
    May 2011
    San Antonio, TX
    Jordon Worktop 2 Door Cooler - Fixable?
    I have a Jordon Worktop 2 Door Cooler that came into my possession for nearly nothing. Build quality is pretty good, it has the thickest insulation I have seen.
    I'm trying to determine if this unit is worth saving.
    Upon inspection I find:
    1. Nearly no refrigerant (R134a). Upon attaching the gauges, I got a weak hiss, and the needles didn't twitch. 0 psig.
    2. No acid smell as far as I could tell.
    3. The aluminum evaporator has a bunch of pinholes, widely distributed.
    4. The condensor and compressor look nearly new under visual inspection.
    5. Before figuring out that it wouldn't hold temperature, I ran it for 30 mins or so, the compressor was very quiet. This may be nothing. It's a techumseh.
    So, I'd like to determine the condition of the rest of the system.
    Here's what I figure I can do:
    a. Cut out the evaporator, braze the pipes closed and pressure test the system without the evaporator.
    b. Check the ohms on the compressor windings (no meggar )
    Is there anything else you guys would suggest?
    Is there anything I can assume from a rotten aluminum evaporator? This pinholes looked like they rotted from the inside outward.
    How does one test the oil for acid on small appliances? Do I have to cut the compressor out of the circuit and pour it out? Can I force it out with nitrogen?
    Even thought Jordon is out of business, I can get a replacement evaporator, same as the old one.
    Thanks!
    May 2011
    San Antonio, TX
    Oh two other items.
    I'm not worried too much about my time into this, as I'm chalking it up to my education.
    I hold an EPA 608 Universal Certification and the required local licensing.
