Results 1 to 13 of 13
Thread: PVC Thread Sealant Needed
05-25-2011, 10:27 PM #1
- Aug 2006
- 2,439
Our Plumber quit, so I got this. In a lab they have a Blue Catch basin under the sink, in case something goes down the drain that wasn't supposed too. There is a Blue Nylon, 2" FPT fitting welded to the Basin. Threaded into that is a Blue PVC nipple. I can't stop it from leaking with Teflon tape. What plastic safe Sealant can I use, on what probably is a stretched Nylon fitting?
05-25-2011, 10:34 PM #2
Any thing with teflon in it, or maybe even a combination of tape and pipe dope with teflon. Seems to me most PTCs say right on the can if it can be used on PVC or not. Are you sure you don't have a crack, it's hard to beleive that even with no sealent on it it wouldn't leak since there is no actual pressure on it.
Just had another thought, do you have any silicone caulk handy. I have used that on threads before, they can be a little harder to break loose later but it's worth a try if the other doesn't work.
05-25-2011, 11:00 PM #3
Rectorseal T-2 or Tru-Blue. I never have good luck with teflon tape.
Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
05-25-2011, 11:41 PM #4
Professional Member*
- Feb 2010
- Cal
- 1,323
I like the silicone method as per kls. Thick and good sealing properties but low strength so it can be dismantled.
Female plastic fitting stink. They either stretch or crack.
05-26-2011, 06:26 AM #5
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,211
are you using the yellow or red teflon tape
they're both thicker than white
05-26-2011, 09:53 AM #6
- May 2010
- 1,289
Plumbers putty
05-26-2011, 10:26 AM #7
I've had good luck on PVC with silicon or Yellow Teflon
THE MORE I LEARN
THE MORE I FIND I DONT KNOW
Cancer Survivor
And Dam Well
Plan On Staying That Way
05-26-2011, 10:29 AM #8
Can you get a fernco around it?
They are ugly as sin, but they stop leaks.
05-26-2011, 01:41 PM #9
- Aug 2006
- 2,439
What I really need to do is use a Hot Glue gun and Hair Dryer on it. I'm sure the lab people are twisting the fitting everytime they work the union, that's on the other end of the nipple. There's a lever to open the drain, that's on the other side of the Basin. It can have three feet of water on the fitting, before the sink over flows.
05-27-2011, 08:29 AM #10
Permatex non-hardening sealant.
05-27-2011, 08:33 AM #11
Just glue it with PVC cement on it like one of my competitors did on a 52 Unit building's air handlers. Glues the threaded fitting right to the drain pans. Unreal.
05-27-2011, 05:07 PM #12
- Sep 2008
- 500
I've done up to 2" with real tuff a teflon based thread sealant but I'd expect any pipe dope to work.
05-28-2011, 02:02 PM #13
- Aug 2006
- 2,439
Just a little update. The 2" Nylon fitting that's welded to the plastic catch basin is not tapered. Also the lab workers aren't using the back-up wrench, that we supplied, on the Union nipple. Thirdly they are using the nipples as handles when they pull the basin to clean it.
