Results 1 to 7 of 7
    Nov 2005
    California
    Question Armaflex on refrigeration piping help!!
    I was wondering if anybody can supply me with detailed instructions on how to fabricate a four piece fitting that fits over a 90 degree elbow. I do not want to use a 45 degree angle. I believe this four piece elbow is cut at either a 30 or 33 degree angles. However I would like somebody to direct me to a site or point me in the direction of how exactly you cut these pieces. I am insulating 7/8 copper pipe with 3/4 inch armaflex. The armacell/armaflex link from there website does not go into detail on how to do this. attached is some info I have found, but not exactly what I need. If anybody can help I would greatly appreciate it.
    http://www.armacell.com/www/armacell/ACwwwAttach.nsf/ansFiles/017-005-NA(NA).pdf/$File/017-005-NA(NA).pdf
    This site shows what Im trying to fabricate but they do not go into detail on exactly how to measure for these cuts.
    http://www.terrylove.com/forums/show...ou-should-know
    Jan 2006
    DFW Metroplex
    I take it you aren't able to simply push the insulation onto the pipe and around the elbow?
    Never had the time or patience to attempt this type of cut.....I'd cut the 7/8" pipe and install a coupling before dinking around with all the angle cuts.
    But that's just me.
    Finally, to answer your question - other than the diagrams shown on the Armaflex box, I am not aware of anything showing the specific angle cuts you wish to make.
    "The problem is the average person isnt tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and its not in the movies they watch, and its not in the few books that they buy, they dont get it" - Jack Canfield
    Jul 2000
    Guayaquil EC
    Here a link to their installation manual:
    http://www.armacell.com/www/armacell...-00-ENIran.pdf
    (The multi-part elbows are shown on p.36-37)
    Nov 2005
    California
    Thanks Icemaster for the link to that. I could not find it earlier.
    Winter Haven, FL
    I have always just cut a "v" partway through the insulation, and glue it together.
    Vancouver , BC
    hop on a supermarket install crew and you will learn real quick how to armaflex
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by neumonic View Post
    Ain't that the truth!
