Results 1 to 2 of 2
    Apr 2005
    replaced suction accumulator....when looking inside inlet and outlet of accumulator ....which is which????....cannot tell...one side goes all the way down...the other side hits some wall type resistance.....then i replaced drier....vaccumed and recharged....low side stayed at 20psi...high side stayed at 150psi...i think i have a bad expansion valve....any ideas,,,,thanks....
    coldair99
    Apr 2003
    California
    sounds like you have a restriction of some kind, possibly at the indoor metering device. It also sounds like you may be undercharged. just a guess...more info
