Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 55
Thread: traulsen
  1. #27
    Ma.
    well go the compressor in., the system vacuumed and about 75%of factory charge in.... to find no suction pressure... looks like I have to find a restriction... had 135 high side with 0 low side with and no ccpr ajdusments help
  2. #28
    Jan 2010
    Quote Originally Posted by JF254 View Post
    If you went with MP66 (R401b) don't panic just yet. @ 1/2 psig. your temp. is -20*
    And your discharge looks good to depending on the ambient @ the condenser coil.
  3. #29
    Ma.
    even with a 74 degree box?
  4. #30
    Cap tube?
    What gas did you put in?
    We are not mind readers
    Still seems short on charge. could be around 25%
  5. #31
    Ma.
    mp 66
    cap tube.
    new filter drier (no temp drop)
    called up traulse got the specs for the cap tube.. they want .049 all I can find is .050....
    is mp66 100% of charge on r12? I was going to start at 75 and work my way up.
  6. #32
    Jan 2010
    How long did you let it pull down ? It's going to take some time with a cap tube.
    Did the fans come on ?
    What's the frost pattern on the coil ?
  7. #33
    Ma.
    ran it for 20 min. the fans never came on... every once in a while I would get a suction of4-5 psi and it would start getting cold and the just bottom right out to zero. ambient at the coil was 80 (off the top of my head)
  8. #34
    Winter Haven, FL
    20mins might not have been long enough.
  9. #35
    Ma.
    Quote Originally Posted by Joe Harper View Post
    I was starting think that after he asked.....
  10. #36
    Winter Haven, FL
    Your fans might have come on for a very short time. You might need to pull the fan delay switch and test it.
  11. #37
    st.petersburg,fl
    Lightbulb
    If you took your SH & SC readings you could end the guessing game
    Hope this Helps....
    Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
  12. #38
    Ma.
    not guessing at all subcooling of 11 and superheat of 78
  13. #39
    st.petersburg,fl
    Lightbulb
    You are low on refrigerant...
    Hope this Helps...
