Results 1 to 13 of 23
    Aug 2005
    I live in Daytona Beach. I'm trying to get a load calculation done on my house. Every company I call asks me for the Building plans for my house. Is this a requirement? My understanding is that they should come to my house, take the indoor measurements and using software be able to recommend the tonnage required for my home. Also is there any real cooling benefit to purchasing a variable speed unit. Thanks!!
    Florida
    They want to do the calc off the as-built plans. You're right......they should come and measure your house, and make sure no additions/subtractions have been done.Also check out the existing system. when you find the company that will come out, you most likely have a winner.
    SE Michigan
    A good HVAC contractor should be able to come to your home and get the necessary measurements to do a manual J load calc. I always provide this with the proposal.
    Depending on your floor plan, a variable speed system can be an excellent choice in controlling humidity and stratofication.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Aug 2005
    Thanks. My house is an L shaped ranch. No Basement(Florida). I have almost 2300 sqft. I currently have a 3 ton heat pump system (Rheem). It's 10 yrs old and I'm sure has lost a great deal of it's effciency. I've had 4 qoute so far but no one will do a load calculation. I think I'm going to take the advice from the previous post and only consider qoutes from company's that will do the calculation. If I can find one. Can I hire someone to do the calculation??
    Jan 2005
    You can always do it yourself.
    http://hvaccomputer.com/talkref.asp
    Aug 2005
    Thank you, if I can't get someone to come out. I'll will give this a try. I would just hate to screw it up.
    Apr 2002
    Sketch up your house plans
    http://www.ductstrap.com/
    Dec 2003
    If the 3 ton has worked well in the past, i'd go with another 3 ton. Load calculation is not an exact science.
    Oct 2002
    Mahopac NY
    Your kidding right?
    Dogs truly are man's best friend!!
    Dec 2003
    Not kidding. He said he had a 2300 ft2 house in florida. If the 3 ton has kept the house comfortable it is not to small. I dont think 3 ton is to big. Just right.
    Aug 2005
    Load calculations are very critical..always start there
    Oct 2002
    Mahopac NY
    To many things could have changed, (as far as the load requirements go), over the life of that system. If your not performing a load calculation, your just guessing.
    [Edited by lonnirat on 08-25-2005 at 06:56 PM]
    Aug 2005
    I have read this forum for a few weeks before registering. The consensus seems to be that a load calculation is a good starting point. I am going to try and get somebody to do one for me. I am willing to pay someone to do it, but I have called 6 different HVAC local company's and they all asked for the Building Plans, I don't have them. I can measure the inside of the house myself if that's all that is required. Is there more involved in a load calculation than just the interior measurements of the home???
