Results 14 to 16 of 16
    Mar 2002
    Richmond, Virginia
    There is nothing more frightful than ignorance in action....Mark Twain
    SW FL
    Question MFG & Model #s
    Originally posted by kcroat
    Does anyone have an estimate
    (hopefully based on some data)
    of the loss of efficiency that occurs if you put the condensing unit on the roof in full sun?
    ACTUAL data based on condenser air temperatures
    can be provided with
    a KNOWN manufacturer and model numbers.
    Designer Dan
    Aug 2005
    MrBillPro made a statement earlier about a system where the condenser was inside the attic with the hot air vented to the outside. I cannot comment on the efficiency claims but can verify this system exist. It is found mostly in commercial applications. It is referred as a "Single Package Horizonal Unit". There is actually duct work for the condenser seperate from the conditioned space ductwork. A description and a picture of this design can be found in the following book:
    Principles of Air Conditioning 5th edition
    V. Paul Lang
    Unit 18 Page 303
