Results 1 to 13 of 16
    May 2011
    central indiana
    Confused Multiple Evaporator Failures
    Have never ran into what I have been told is most likely a Sulphur issue at a customers home, we installed new equipment 2 years ago due to many problems with the A/C
    Evaporators we removed were fullof pin holes install all equipment brand new lasted about 6 month same issue.
    Was given advice to uase all Aluminum coils, we just put them in, but am still concerned about what in the atmophere is there someone out there who could test this copper to verify whats causing this problem??
    Jun 2010
    northwest connecticut
    if it's a newer home check out chinese drywall !!!
    May 2011
    Winter Garden fl.
    Second that on the chinese drywall
    what is chinese drywall?
    Last edited by Chris_Worthington; 05-22-2011 at 11:56 AM. Reason: re-worded fowl language
    Mount Airy, MD
    Quote Originally Posted by hvac wiz 33 View Post
    http://en.wikipedia.org/wiki/2009_Ch...ll_controversy
    OP I corrected the title spelling, it was bothering me
    wow .. thats crazy. i knew nothing about it. thanks for link
    May 2011
    central indiana
    the addition was done around 1977
    so I do not beleive its the dry wall
    Here is what make no since at all there are 7 building on this pice of property all owned by the Church and the parsonage is the only one with the problem showing up in the evaporators
    Southeastern Pa
    You might want to ask an environmental firm to offer an opinion. In the 1970s there was a spate of formaldehyde foam insulation. If in those walls it could be gassing off.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mount Airy, MD
    Quote Originally Posted by timebuilder View Post
    I always thought that formaldehyde was used for other things in the 70's?
    May want to consider having an Air specialist involved as it does not sound healthy what so ever
    May 2011
    central indiana
    I do beleive it is all bats in wall and cellulose in attic
    would any body be able to recommend and air quality specialist in Indianapolis area
    I'm definanetely looking for answers as there is some children living in this home. Thanks for all the help
    Southeastern Pa
    Quote Originally Posted by Chris_Worthingt View Post
    I'm lost on that one. I saw stuff in my biology class in '66 that was in a jar of Formaldehyde. Maybe it had a use of which I am unaware.....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    Quote Originally Posted by putnam county View Post
    Let us know what you find. I'll bet it's a short list of things in a house that will hurt an evap. Mold acids, insulation, paint and carpet voc's, meth lab....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mount Airy, MD
    PCP
    What are the street names/slang terms?
    Angel Dust, Embalming Fluid, Killer Weed, Rocket Fuel, Supergrass, Wack, Ozone
    http://www.drugfree.org/drug-guide/pcp
    http://parentingteens.about.com/cs/m...cmarijuana.htm
    Green, Loveboat, etc....
