Results 1 to 4 of 4
    May 2011
    North Dallas, TX area
    Any geothermal system work like this?
    Most contractors tell me that they have to drill one 200-300' vertical well for every ton of AC/heat (plus an additional well, according to at least half).
    They all seem to sell a dual-stage system (with variable speed blower), although one contractor uses two systems (a single stage plus a dual stage) to get an effective 3 stages.
    Why couldn't they (say for a 5-ton system) create the equivalent of a 5-stage system by simply allowing flow to only ONE well to get about 1-ton of cooling, allowing flow to only TWO wells to get about 2-tons of cooling, 3 wells for 3 tons, etc?
    Mar 2011
    SOUTH DAKOTA
    Confused
    That doesn't make much sense. Your equipment is staged by the compressor, the number of ground loops you use would make a difference if you start closing off loops it's going to mess with your ref. pressures just don't see your logic in that
    Apr 2011
    Coastal Maine
    Huh?
    Why re-invent the wheel? These things are developed through real data and research. IMHO, you are way off base.
    Dec 2011
    Sounds like you are trying to make a cascade system out of a geo. If you want to make it more efficient easily then just add more footage to your loop.
