    Feb 2011
    Tempstar smartcomfort 2000 model TCHO36AKA! need some info
    Hi
    just needing some info on this Model ...i'm guseeing it's about 36,000 BTU's ? ( thats why it has the 36 in the model #) but was needing to know about how old this unit may be and whats the lowset outside temp that the heat pump can work at ??
    thanks
    Lancaster PA
    Post the serial number, that will tell the age. I believe its good to about -10F.
    Feb 2011
    i knew i was forgetting something LOL the serial # is LOO39 18790
    thanks
    Oct 2002
    Illinois
    this unit was made in 2000
    Ohio
    The colder it is outside the less efficient it'll be though. If you're on nat gas, I would never run it if its colder than 40-45 though. On LP? Maybe a little colder. These aren't hard rules just general guidlines I follow in OH. Sorry, I assumed you have a dual fuel system.
