Results 1 to 13 of 20
    Jan 2011
    Carol Stream, IL
    Confused RTU 48TJE KEEP FREEZING
    Hi everyone, hard to learn something new by itself, unfortunately that is my case. I was checking an carrier RTU and i could not figure out why was keep on freezing on me. Finally I evacuate all the refrigerant and came up that the amount of refrigerant was exactly the exactly the same as the label in the unit said, 7.9 lb. So I got to the point to assume that it was getting freeze up because the inside of the building was not to hot???? because, nothing else was wrong. All tips will be greatly appreciated.
    Jun 2010
    I doubt a low load would cause it to freeze up. Check your air flow, blower motor, and duct work.
    Jan 2011
    Carol Stream, IL
    Thank you. I did and everything seems to be find. That's why I was wondering if outside temp will affect that.
    Did you take any readings on the unit other than pulling the charge and weighing it?
    The answer lies within that data.
    Dec 2010
    new jersey
    Fire damper slammed shut....happened to me.
    Southeastern Pa
    We need all the numbers.
    You did gather the numbers, right?
    For example, the temp diff across the evaporator when it was thawed and recharged.
    Superheat.
    Subcooling.
    Outdoor and indoor.
    Stuff like that.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Sep 2009
    Boyertown, Pa
    More info needed. What was the outdoor temp? Is there a fan speed control for the condenser motor for cool weather operation?
    Jan 2011
    Carol Stream, IL
    Thank you every one for your advice, I really apreciate it. Is hard when you have to learn in your own. But thanks God and those who create HVAC TALK !!!!!!!!!!!!!!!. Thank you again.
    Denver, CO
    I've had a lot of problems with the headers plugging up on those units.
    Howell, Michigan
    Before you emptied the units freon did you check temperature on both sides of the liquid line filter dryer to see if there was a temp difference? The filter dryer could have debris or to much braising leaked silfloss into filter itself creating a restriction How old is the unit?
    Good Luck! Kimosobee
    Jan 2011
    Carol Stream, IL
    Thank you, and yes I did check the filter, it was ok. no difference in temp.
    May 2011
    West Virginia
    Your problem is it is a Carrier!
    Tell them that they should look at getting a Lennox. Ha-ha-ha!
    Southeastern Pa
    Quote Originally Posted by Assassin View Post
    Everyone has an economic point-of-value. Lennox is not the right choice for some retail clients.
    As far as durability, I replace just as many condenser fan assys on Lennox as I do Carrier. In fact, I was at a location last Monday with seven bad fans out of five RTU's. Today, I replaced a completely blocked, and I mean 100% blocked filter dryer in an LGA.
    Good units? Sure. Perfect? No way even close. In fact, come winter, those JCI blue boxes are a staple of my no-heat calls on Lennox units.
    I'm gonna miss the blue boxes....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
Tags for this Thread
