    Desert Southwest
    Belimo Select Pro - Windows 7 compatability
    Anyone figure out a way to get it to run on a Win 7 machine. Can't get it to load and run from the CD they sent me and the newer version on the web won't fully load and run either.
    Jan 2003
    We have 2 techs running win7 and select pro. Not a huge fan of it myself. I'll ask if they blessed it first, but I don't think I heard any complaints about it not working.
    Jul 2009
    Kansas
    Try messing with the compatibility settings, and if all else fails you could either set up Dual Boot, or use a Virtual-PC software to run XP on top of 7. http://www.microsoft.com/windows/vir.../download.aspx
    Desert Southwest
    Quote Originally Posted by Greend88 View Post
    I run CCT on the Virtual Machine in XP Mode and when I tried to load it I was prompted to install some other framework 2.0 software but it would not run doing that either and W7 Compatability mode came back and said it was incompatable.
    I'll have to see if I can dig up an older machine to run it on other than this new DELL E6510 I just was given which I don't care for due to the extra buttons associated with the Pointing Stick which seem to have a mind of their own even when disabled.
    Desert Southwest
    UPDATE - GOT IT WORKING
    After re-installing it I allowed the download that goes to the website and load all 1200+ PDF's to run. It took a good half hour or more but it is working now on W7.
    Thanks to all who responded.
