Thread: AX Lon Links
    Oct 2007
    England
    AX Lon Links
    I need a bit of clarification for my ever thickening brain.
    If I make lon links in the link manager from a device back onto itself (nvo to nvi) which is connected to a Lon network with a Jace as the Lon network manager.
    So long as I have performed a 'Bind' on the links; and possibly commission the device, I could then technically switch off the Jace and the links would still work. Yes?
    I.e. the device would then work stand alone sending data back onto itself.
    This is how I would expect it to work but I cannot find any information about this in Doc Lonworks.
    Keith
    May 2002
    LON is a peer to peer network.
    Are you familiar with LNS LON? (NL220, lonmaker, Circon NI, Lonwatcher, etc..)
    Do you walk away from the site with your software after you are done?
    Oct 2007
    England
    I thought as much.
    But someone posed me the question today and I said that I was pretty sure that if the Jace failed then the system should operate as pretty much as normal.
    I then said I would double check though just to make sure. And sure enough I couldnt find a definitive answer.
    Keith
    May 2002
    Well, the protocol is ISO 14908. If they are using it they need to make reasonable attempts to use it correctly.
    Any proxy linked points would be gone. for example let's say you link OSA from one controller to another but do it from proxy points under the point folder to proxy points under another devices point folder, those are in the Jace and go where the Jace goes. But if you link device with OSA direct to other device, that will stay. Like sysint said hinted to, links need to be done with thought and correctly for the desired outcome.
    Nov 2007
    Phoenix, AZ
    Links
    Quote Originally Posted by Keith D View Post
    Keith
    Yes, the link is in the network. Just like a link in Lonwatcher or Lonmaker. After you link the device to its self or device to device, bind turn off the jace and take it away if you want, it will still keep working.
    GregF
