Results 1 to 13 of 16
    Apr 2010
    Windsor, Ontario Canada
    Hs36 Ac voltage accuracy
    Hello all, I just picked up a fieldpiece hs36 multimeter. It looks pretty cool and I like all the features. I just got a question about it for anyone who owns fieldpiece. Is it normal for the meter not to be at zero when you set it to ac voltage? Without the leads being in contact with anything it shows a voltage between 2.3 and 2.9v or so. It seems to have some kinda delay or needs calibration. I had a fluke 116 before which seemed really accurate.
    I would appreciate some input. Thanks
    Jul 2005
    Quote Originally Posted by moenaboulsi View Post
    The HS36 is a slow responding meter. However, the 2 or 3 volts you're seeing is probably just stray voltage in the air that the meter is picking up. If you short the leads together that reading should disappear.
    Apr 2010
    Quote Originally Posted by hvacrmedic View Post
    Thanks for the info, I'll try shorting out the leads and see what happens, it's hard to adjust to a slow responding meter like that coming from a fluke. Overall meter looks really good.
    Apr 2010
    Not really any difference when you short the leads. I mean the measurements are accurate when your testing, but when on stand by the numbers are all over the place when you move the leads around, it jumps between 2 and 80v or so when they're being moved. Kinda throws you offer track
    Delaware
    Millivolts?
    Always here
    Apr 2010
    Quote Originally Posted by energy star View Post
    Millivolts?
    Vac
    In the work truck
    Should have stick with the fluke. Ok seriously tho. I think if you look at the display you'll see mv somewhere. Your not reading v. The higher end flukes do it to. Are the numbers bouncing around a lot?
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    Delaware
    Vac? See the little m
    Always here
    Jul 2005
    You got your question mark in the wrong place. I had to read it twice.
    OP, the HS36 is an autoranging meter. That little m is hard to see sometimes, especially if you're not looking for it.
    NE OHIO
    Yeah wish it had manual range also, thats only thing i dont really like about mine but id find something i dont like with just about all of them
    Apr 2010
    Quote Originally Posted by Pascone10 View Post
    The display says AC on the top left, and just "m" on the center bottom. Iam sure it's set on ac volts because I get 120v on a receptacle. It bounced around quite a bit when the meter and leads are moving around
    Apr 2010
    Maybe your right mine looks exactly luke yours when it's standing. I reads 1.8. With the ac and m on the screen. What's Does that mean?
    NE OHIO
    its very sensitive
