Results 1 to 13 of 29
    Dec 2009
    walk in refrigerators
    what happens to the evap coil when the door is left open when a delivery comes, I was told the coil ices up why is that. and also what happens to the walk in when the gaskets are leaking.
    Apr 2003
    Maple Grove, MN
    It can ice up in either case. The evaporator coil runs colder than 32 degrees F. The cold coil attracts humidity to it. The only time it gets a chance to thaw out is when the box is down to temperature and the compressor shuts off. If the door is left open too long or the gaskets are bad, the compressor will run too long without enough resting time for it to defrost itself.
    Dec 2009
    than you that makes total sense do you recommend any good refer books
    May 2011
    ICE ON EVAP
    YOU CAN AD A DOOR SWITCH TO TURN OFF EVAP FANS WHEN DOOR IS OPENED
    In certain circumstances it could overload the compressors. This is why production walk-in refrigerators and freezers have suction regulators. I've worked on Military containers, that have suction controls and liquid injection.
    I only have to make it work till I retire.
    Jan 2010
    Quote Originally Posted by COLEMON2 View Post
    Works great till someone leaves the door open. You then have a real problem.
    Apr 2003
    Maple Grove, MN
    This would be a great idea IF you WANT the evap to freeze up. Otherwise, just CLOSE THE DOOR!
    Mid Michigan
    Leaving to door open for deliveries doesn't really bother me.
    Now we have a big fundraiser every year at work. I have found that the
    kitchen workers will leave the walk in freezer door open for hours at a time
    then they wonder why the freezer isn't hold temp? Get them trained
    up better now.
    Waddya mean don't thaw out the frig with a knive?
    Feb 2011
    Indianapolis, IN
    This is also why you need a off-cycle defrost to allow the box to defrost its self out, @ lest 2x in 24 HRS. every 12 hrs
    May 2011
    location
    Quote Originally Posted by ammoniadog View Post
    depends on amount of common sense
    May 2011
    thanks
    Quote Originally Posted by madhat View Post
    Nice info thanks for information
    White Lake, MI
    Simple strip curtain helps - costs about $100. It wll pay for itself in months.
    Moved to Refrigeration and ice making forum.
