Results 1 to 13 of 24
Thread: Vacuum Pump
05-15-2011, 02:20 PM #1
- Apr 2011
- San Bernardino, CA
- 80
Vacuum Pump
I need help guys in deciding what brand to buy, what are your guys favorites i am just doing residential work. I have a JB 5cfm platnum now but stoped working and need to buy another
05-15-2011, 02:26 PM #2
If you want to have two pumps, purchase a rebuild kit for your JB. Have you been dissatisfied with the JB? If you're working resi equipment primarily, then you don't need anything much bigger than 5 CFM. Our company has several different manufacturers and can't find any significant differences between the pumps. We generally purchase a 7 CFM pump and get good long service from them with constant oil changes.
I'd recommend a new pump to get you going right away and rebuild the other pump so you've got a good stand-by if needed.If YOU want change, YOU have to first change.
05-15-2011, 02:30 PM #3
- Apr 2011
- 80
Could i just get a rebuild kit at any local supply house?
05-15-2011, 02:31 PM #4
The might have on already on hand or could at least order one for you. Asking them is, of course, the answer to that question.
05-15-2011, 02:31 PM #5
I've used several brands. Currently have JB and no issues. Change that oil EVERY time you use it.
If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
05-15-2011, 02:39 PM #6
- Apr 2011
- 80
I dont know much about these pumps but could it just be the valves need to be replaced?
05-15-2011, 02:42 PM #7
05-15-2011, 02:55 PM #8
Is that in your truck or your pump? Perhaps you do both and make a day out of it.
05-15-2011, 03:01 PM #9
05-15-2011, 03:50 PM #10If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
05-15-2011, 03:54 PM #11
- May 2010
- Connecticut
- 30
I have always used Yellow Jacket and never had any isuues.
05-15-2011, 04:49 PM #12
I have a yellow jacket 6 cfm. Sometimes I wonder if it is pumping to capacity. Recently I was told it wasn't because it was too quiet when it starts getting into a deep vacuum. The tech said it should sound like it does at higher pressures. Any comments!
05-15-2011, 05:32 PM #13
