Results 1 to 13 of 20
Thread: Funky Clothes
08-16-2005, 10:41 PM #1
Professional Member*
- Nov 2001
- east kansas
- 7,980
My washing machine doesn't seem to be washing well. It goes through all the motions, but the clothes are funky.
I ran it through a cycle and noticed a lot of soap left after the tub drained. Then it spun and filled for the rinse. Drained, but still a lot of suds left on top of the clothes.
Ran it through just a rinse and the water turned gray again and left suds.
Any ideas?
08-16-2005, 10:44 PM #2Senior Tech Guest
Call the maytag man...he's sorta lonely these days...and my wife won't let me with-in 5 feet of ours...
08-16-2005, 10:46 PM #3
could be something plugged up in pump or to much soap. try running empty on hottest setting for a few cycles to flush it out.
or could just be extra funky summer work clothes
08-16-2005, 10:54 PM #4
- Nov 2001
- east kansas
- 7,980
Thought of running it empty with vinager. The water seemed to drain okay because I could hear the pump cavitating.
08-16-2005, 11:46 PM #5
Does it ever drain out?
or is it always the same water?
Walter Matthau
08-17-2005, 12:11 AM #6
- May 2005
- 447
Hey Lynn...
If you post some info on your washer, i.e.: model/serial, I may be able to help you with your washer problem. Is your washer a Maytag Neptune? Are you on a well or city water? And when you say "funky", do you mean "musty/moldy"? Let me know.
Jerry
08-17-2005, 07:26 PM #7
- Nov 2001
- east kansas
- 7,980
Typicial HO
Roper
RAB1121EW1
CG1106903
Yes it drain compleatly. Brenda ran some vinigar through it today and changed to a different soap and she thinks it was better.
Spotts, did you see the pic of my brother's truck?
08-17-2005, 08:36 PM #8
- Jul 2005
- 1,035
I use pool chlorine to clean out our home drains and to degrease the dishwasher once a month. With 4 females in the house hair clogs are common. I pure a gallon of it straight into the drain...and dishwasher and it cleans the pipes out really well (a its better than drain oh) maybe running a gallon or two though an empty cycle or two will clean out the soap residue. don't let it touch anything it will destroy cloth. Might be worth the $2.50 for a jug of it at wal-mart.
73% of Americans say that illegal immigration is a problem. The other 27% say, "No habla inglis!"
08-17-2005, 09:07 PM #9Originally posted by doglips
I hope your drains are plastic.
If using soap powder, It's best to put the soap in and fill with water prior to putting the clothes in. That's what I'm told.
08-17-2005, 09:12 PM #10
I don't even know how to turn ours on.
08-17-2005, 09:37 PM #11Don't tell her that, or I bet ya be learning.Originally posted by Dowadudda
08-18-2005, 12:15 AM #12
- May 2005
- 447
Hey Lynn...
Take a gallon of cheap vinegar, pour it in the tub, leave overnight, in the morning, fill with hot water, and soap, run thru the longest cycle, that should clear up your problem.
Jerry
08-18-2005, 08:57 AM #13
"Funky Clothes" ???? I thought he was talking about bell bottom hip huggers and pasely shirts.
