Results 1 to 7 of 7
    Aug 2005
    Question
    I see a lot of people talking about making sure a jumper is set from Y to O in order for Comfort-R Enhanced mode to work. My system is configured for this mode, however, I have verified that this jumper is not there.
    Can someone verify that I really need this jumper?
    Nov 2000
    Eastern PA
    If it is the same as the Goodman board the jumper would be removed if this is a heat pump system.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Is it an AC only system? This post should help...
    http://www.hvac-talk.com/vbb/showthr...threadid=81270
    Aug 2005
    My system is an electric A/C and Heat system.
    Nov 2000
    Eastern PA
    Is the heat part a heat pump or only electric resistance heaters? If a heat pump, your thermostat should have a mode setting for "EM" heat.
    Aug 2005
    I have an electric heater....toaster oven.....I don't have a heat pump system at all.
    You don't need the jumper from Y to O on the electric air handlers, just on the XV80 and XV90 gas furnaces.
