Results 1 to 13 of 18
    Feb 2005
    Dothan, Al
    Please excuse me if ya'll have heard this one before.
    Why do some manufacturers install 1 pole contactors on some residential systems ?
    Was asked this by me tech ( my wife )
    Oh yea, just asking, how many female service techs ya'll seen out there ??
    Richard
    Originally posted by bornriding
    How many female service techs ya'll seen out there ??
    Richard
    Six years...one inside the company...zero outside.
    Get back to work.™
    I'm guessing that the one pole contactor was made to save money, because the compressor won't start if it gets only 120 VAC... The cost of springs, contacts, etc... is less than a simple buss bar on the second 'leg'.
    If I'm wrong...
    It's the medication I'm on....
    No.... I meant... the cost of springs and contacts is not nearly as less than........... ah fer-gittit......
    Jul 2003
    Crankcase heat
    ummmm..... sorry Joker, you can have crank case heat with a two pole, one pole or three pole....
    Don't mind me... it's the meds...
    but how is that a potential reason? This old dog can learn new tricks....
    Feb 2005
    Dothan, Al
    Am dissapointed in the lack of response, Oh well
    Joker is right - one pole contactor used due to compressor winding used as crankcase htr.
    Thanks all for yur response
    Richard
    Feb 2005
    Barrie, Ontario
    Richard
    I'm always the late guy...
    If I may add, I understood it started as a crankcase heater, trickle power through the start winding using the capacitor like a resistor (Did they have to have bleed resistors?)to warm the compressor up. But the contactors stuck for another reason...Cost. Not too many manufacturers use the start winding heater theory anymore if any. Modern caps and windings probably can't take it.
    I always thought it interesting that some older Carrier 3ph units used a 2 pole compressor contactor and wired the 3rd direct...not for the same reason as above of course. I always thought it was kind of dangerous and stupidly cheap.
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2¢.
    My competition are my best salespeople!
    New Mexico
    Those things kill people.
    Tracers work both ways.
    I don't get it.
    and
    Two. Marylyn Roth was President of Syracuse RSES a number of years ago.
    I don't get it-------if you are using one leg of the power for a "trickle charge" where is the completed circuit.
    Jacksonville, FL.
    On older systems they wire the CCH to both sides of the buss bar on single-pole contactors thereby making a complete circuit.
    I still don't understand how that's supposed to work....
    WHY?
    Been around a few years, I'm wracking the single brain cell left... maybe Bornriding can explain the exact science of that.... or mayby NormChris...
    Support the claim, just don't repeat it.... I'm listening.
