    Anyone familiar with Nature's home "microguardian air scrubber III". Spec'd to be put in a new home. Looking for any info. Thanks
    looks like snake oil
    May 2005
    Lubbock Texas
    If I remember right. This unit is a giant filter box with a merv 14 filter in it and a UVGI Light. Be careful of the pressure drop across a merv 14 filter. This is getting real close to a hepa style filter at 90 to 95% efficiancy rating where a hepa is like 99.95%. Also avoid direct site of the UV bulb, it will give you the worst welding burn you have ever had
    The premise of ventilation is that the OA is clean or of sufficient quality to be used for dilution. Traditional ventilation is somewhat being threatened by the fact that the EPA is changing the requirements for outdoor air quality which is creating non-attainment zones in what is now becoming a significant portion of the country. That means that buildings in those areas will need to clean up the OA before they bring it into the building.
    www.genesisair.com
    Genesis Air Inc.
    Calls for placement on high velocity units where pressure drop may be more of a problem?
    Midwest
    your better off with a micro power guard and a seperate oxy quantam IIe.. much cheaper and will do the same
    Jacksonville, FL.
    You must be involved with AT500.
    To answer your question I've heard of them but never used them.
    WHY?
