Results 1 to 11 of 11
    Hell Hole Swamp
    What do you not do when you find the "herm" wire burned off of a run capacitor?, no multiple choice here, you can add what you should do first before attempting a repair if you like.
    Jul 2003
    Dont touch the terminals on that cap til its been discharged
    Hell Hole Swamp
    Did you learn the hard way too?
    Jul 2003
    Talking
    Yep. You havent lived til youve been bit by a cap!
    the snap is scary enough when you discharge one
    Hell Hole Swamp
    Yep, I had one the other day that sounded like an M-80 going off
    Feb 2005
    Barrie, Ontario
    Ahem... An open start winding on the motor can do the same thing. Leave a cap in a charged condition.
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2’.
    so isnt it a good idea to put a resistor across the terminals of a run cap to bleed off that charge ?
    Jul 2003
    Talking
    An old screwdriver is my remedy
    South Dakota
    Shorting a capacitor with a screwdriver or a wire can discharge the capacitor too fast and damage it. Use a resistor!
    Jul 2003
    Unhappy
    I know
