    May 2011
    manifold lubrication
    i recently took my gauge manifold and all the valves apart to clean it since i jst got them used from another tech in the company. should i be lubricating the valves when i put it all back together?
    In the work truck
    what type of manifold? Refrigeration oil should work ok..
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    Rapid City, SD
    Or a bit of vac pump oil. I would think for such a small amount needed just about anything would work.
    You can take those things apart?????
    don't think I've ever really considered cleaning and lubricating a manifold
    Rapid City, SD
    I take mine apart every 3 months, and every 3rd thursday of the month I check the torque on all fasteners on my manifolds.
    Ok, no, I don't... it'd be nice if I had that much free time with nothing else to do though.
    I usually only rebuild my manifolds after something gets broken, or if it starts getting leaky and won't pull a good vacuum. Or if I some how get some nasty sludge in it from a bad burn out.
    Jul 2009
    In a mechanical room....
    Quote Originally Posted by amickracing View Post
    You had me going for a min, I was like get the crap out of here!
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
