Results 1 to 9 of 9
    Jan 2010
    Routine A/C Maintenance
    We've lived in our new home for about 5 years and the Armstrong A/C condensors have never been serviced. We live in the south so we've recently begun our A/C season.
    How often should the condensors be maintained? I'm probably going to find a contractor to check out the units but I don't know what they should do as part of the service call. What do you suggest be done to these units? I haven't noticed any problems with them so far. Should someone checkout the air handlers (furnaces)? Thanks.
    Feb 2011
    North East Ohio
    clean condenser coils with chemicals if it hasn't ever been done. check capacitors and contactor for pitting. Verify proper airflow before checking charge. check and record OD and indoor temp, SH and SC. If system is found to be low on gas, have them look for a leak, rather than just blindly putting in a "top off" It is not a bad idea to amp the blower motorto make sure all is well with it. This is what I do on a A/C maintainence call
    Virginia
    Quote Originally Posted by NCHeat View Post
    I agree except Armstrong coils have a coating that coil cleaners will damage I like to just hose them out or use a citrus based cleaner and water
    Apr 2011
    San Bernardino, CA
    simple green would also work good
    Myrtle Beach, SC
    Quote Originally Posted by catmanacman View Post
    I agree.
    Remember, Air Conditioning begins with AIR.
    Feb 2011
    North East Ohio
    Thanks Catmanacman
    That's good info. Could help me from really screwing something up
    Jan 2010
    Thanks guys. As luck would have it, one of my AC condensors died last night. Refrigerant line outside frozen over. Service tech coming out later today.
    Mar 2011
    Edna Bay, Alaska Highest concentration of black bears in the US
    Lineset froze=indoor coil iced =airflow problem, or low charge. Check your filter.
    Jan 2010
    Quote Originally Posted by Dr.phil View Post
    The problem was diagnosed as a bad furnace blower motor which had to be ordered.
Tags for this Thread
