Results 1 to 12 of 12
Thread: Carrier RTU's
    May 2008
    Central Fla.
    Carrier RTU's
    Ok, I have several brand new units for a job that fell through. Tonnages very between 2-1/2ton and 4ton. Some single phase some 3ph.Most are 410a couple are r-22.all are a/c's some have heat (some gas packs)some don't. They can be pad mount also. $1,300-$1900. Let's make a deal !!!
    May 2008
    Central Fla.
    Got views, no offers????
    May 2008
    Central Fla.
    Price dropped on these$1,000 - $1,200.
    May 2008
    Central Fla.
    OK, Carrier 4ton Gas Pack R-22 3ph 208/230v. Md#48SD-0480905
    I have 2 of these units, and will give them away for $1,100 each plus shipping.These are brand new units still crated. Paid over $2,300.
    May 2008
    Central Fla.
    Next is a Carrier 3ton,3ph 208/230v R-410a 13 seer. Md# 50ES-036-5-TP $1,000. plus shipping each and I have 2 of those.
    May 2008
    Central Fla.
    Carrier 2.5ton R-410a 13 SEER 3ph. 208/230v Md#50ES-030-5 . I have 3 of these and I want $900.00 each plus shipping.
    May 2008
    Central Fla.
    These are in Central Fla. if you pics let me know, also I can give you an idea for shipping costs if you need it.
    May 2008
    Central Fla.
    I NEED TO DUMP THESE BOAT ANCHORS, ANY OF THE 3PHASE UNITS ARE $500.00 EACH. You pick up .
    May 2008
    Central Fla.
    Hello, (tap tap) Mcfly !!!!!
    Atlanta GA area
    Quote Originally Posted by TwincamDave View Post
    If it were me, I would hang on until spring (read that hot WITH humidity). Might do better then.
    GA-HVAC-Tech
    May 2008
    Central Fla.
    I hope they will be gone before then. I need the space in the warehouse.
