Results 14 to 20 of 20
    SW FL
    Exclamation Work Smart
    Originally posted by ravenx
    Fat mans relief
    If your older and slightly wider around the middle, they are great
    Did I hear you say your waist is 46"?
    Designer Dan
    Apr 2004
    SLets leave fat guys alone!
    The laser is nothing but a pointer, it points to the general area the infared thermometer is reading. The infared has optics sometimes 4 to 1 or 6 to 1. This owuld mean if you are 4" from the surface it is reading the average temperature of a 1" circle. Hardly accurate to say the least. If you point the sensor much closer the laser is missing the target where the reading is taking place.
    Use it as a chock block
    Thibodaux, LA
    Exactly they are junk. Great to play with your cat or dog but leave it at your house when you head to work.
    "Football Season again finally"
    Florida
    Not true. The point and click thermometer is great for measuring temps that don't have to be precise(not S/C, S/H). These thermometers measure surface temperature. The farther away you are, the wider area the thermometer is reading. Great to check if a register is working on a high ceiling, as stated. Also breakers, coil temps,etc. No they're not super accurate, but to say they're worthless is BS. If you know what you're doing, they're a time saver and handy.
    Mar 2002
    Richmond, Virginia
    Experience does matter.
    There is nothing more frightful than ignorance in action....Mark Twain
    Dec 2001
    Ocean Pines, MD
    It is a very useful tool. Like any tool you have to buy one of quality, know how to use it, and what it's limitations are. Otherwise get the cat.
    [/B]Did I hear you say your waist is 46"?
    [/B]
    No, I said below the waist i'm fairly thick...
