Results 1 to 13 of 14
    May 2011
    I could use some help fast
    I am getting my bathroom tiled today. My contractor pulled out the old shower surround, and found a wall vent behind it that was not closed up or anything, they just placed the surround right over the vent without closing it. I'm not sure if this is right or not, but it has to be tiled today. I called several plumbers and they cannot get our here today. So my question is this can I buy something to place something over the vent so no air blows out, obviously I know it needs to be done correctly in the basement, but just as a temporary fix so it does not ruin my tile
    Thanks alot
    Chris
    Jan 2001
    Pamnyra VA.
    Stuff a towel down it for now.Make sure you can retrieve it later.
    Rochester NY
    Hmmm. Not sure why it would ruin your tile, but I think they have a tape you can close that duct off with.
    Now if I could just remember what it's called...
    Houston,Tx.
    Pictures would be great.
    Fort Worth, TX
    4 mil thick plastic and foil tape. Done.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Jan 2010
    Athens GA
    The right way to do this is to follow the run back to the main supply duct.Disconnect it there, put a cap on it or a flat piece of metal with an RTV cauck around one side and screw it in place.
    You can do it now or next week and you'll have not problem unless two takeoffs are on the same feed.It won't matter if you let the a/c blow into the basement for a few days while you get the cap and a small tube of RTV.
    Rochester NY
    Quote Originally Posted by REP View Post
    I vote for this answer. Will be easiest to determine which duct to disconnect when the wall is still open. Label the duct leading up wall "disconnected supply behind shower" for future reference/confusion avoidance.
    Feb 2011
    North East Ohio
    Quote Originally Posted by tedkidd View Post
    That's good stuff
    May 2010
    Well when you tile your shower they need to use Cement board and that will cover the duct up for you. Problem solved.
    As to where it's leading, that's for you to find out. Shouldn't be too complicated
    Apr 2011
    San Bernardino, CA
    I also vote for this, easy fix and will not have a problem
    Jun 2007
    Round Rock
    My advice would be to slow down and wait for somebody who knows what they are doing to fix it. I find that when I try to rush things. I end up spending more time and money later than just spending a little bit of time now.
    I like DIY'ers. They pay better to fix.
    Feb 2007
    milford ct
    why would you call a plumber ? is it a waste line ? you should have called an hvac contractor
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
    Aug 2009
    Long Beach CA
    If they just discovered the duct today and are tiling today, then there is more than HVAC being done wrong.
