    Aug 2005
    I've gotten 4 bids on my AC and heating needs. I'm going to be going with a Bryant 3 ton 14 seer and the Plus 90T 2 stage 47,000 low and 75,000 High. The company who will be doing the installation said they normally never use a 2 stage Thermostat with their 2 stage units, they said it's run by the board. I'm think this is more like a timer, first stage 16 min if it doesn't meet the set point the second stage kicks in, is this right? If so, what would be the advantage of having a 2 stage Thermostat? Can you set the times of the second stage going off? How would this help? I'm looking at the Vision Pro 8000 (TH830-U-1008 Multi-Stage).
    Thanks as always!
    On a Bryant, the board bases it on past runtimes. It's slightly better than a fixed timer but far from the comfort you can get from a good 2 stage stat. I'd certainly go with the TH8320 Vision Pro. With single stage stat, once it goes to high it is there. With 2 stage stat, it only goes to high when needed and returns to a gentle low when not needed. So much less cycling which is inefficient.
    burlington county n.j.
    letting unit run by booard will have high stage time on then satisfy and shut off. 2 stage stat will bring on high fire when and if needed then cycle down to low fire till saisfied giving longer cycle times. 2 stage stat better choice. new thermostat wire may be needed.
    i gotta learn to type with more than 1 finger!!!
